Eagle or 440 source #1962097
12/02/15 11:20 PM
12/02/15 11:20 PM
Gateway to the West.
hemi_harvester Offline OP
I know this might cause a melt down but , in the 2K-3K price range who has the best stroker kit ? Summit had the Eagle on sale for 1900 and change.
I want a flat top / 6.760 / 4.15 combo.
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Eagle or 440 source [Re: hemi_harvester] #1962101
12/02/15 11:26 PM
12/02/15 11:26 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I saw that and was thinking of getting the Eagle kit from Summit, But the compression ratio it to high with my heads. If you are running 84cc Edelbrocks the Eagle kit will work. If you have the 78cc Trick Flows the 440 Source kit with d-dish pistons is the way to go. I like the Eagle kit with Mahle pistons.
The only Carbs I care about are under the hood!
Re: Eagle or 440 source [Re: hemi_harvester] #1962102
12/02/15 11:27 PM
12/02/15 11:27 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Every one will have there opinion on this one. I really like the 440 source on the crank, and the eagle rods over the 440 source. I pieced mine together and used the diamond pistons. It cost more, but that's my preference.
Re: Eagle or 440 source [Re: Deepockets] #1962119
12/02/15 11:47 PM
12/02/15 11:47 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I pieced mine together vs. buying a kit and got better parts for virtually the same price.
Molnar crank, Molnar rods and Mahle pistons.
I found AndyF's piston chart very helpful!
http://www.moparts.org/Tech/Archive/bb/BBM_Stroker_Pistons.html
