What are the correct wheels for 70 V code cuda? #1960219
11/30/15 12:54 PM
11/30/15 12:54 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
What are the correct wheels for 70 V code cuda that came with e60-15 tires & dog dish covers? Thanks, GTS
Re: What are the correct wheels for 70 V code cuda? [Re: GTS440] #1960227
11/30/15 01:07 PM
11/30/15 01:07 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
If it came with 15" steel wheels and dog dish caps that would be the 15x7" "450" part number 70-71 hemi wheels. The are pricey wheels.
Matt
Re: What are the correct wheels for 70 V code cuda? [Re: mattsmopars] #1960228
11/30/15 01:11 PM
11/30/15 01:11 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Is the part number the only way to verify them from other 15"x7" wheels or do they have cosmetic differences?
Re: What are the correct wheels for 70 V code cuda? [Re: GTS440] #1960229
11/30/15 01:19 PM
11/30/15 01:19 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
They are a specific wheel. As best I remember they are a 14" center in a 15" band. If you will notice the picture I have attached of the set that is for sale in the wheels for sale section you can see the band is wider where it steps down to the wheel center.
Matt
Re: What are the correct wheels for 70 V code cuda? [Re: GTS440] #1960317
11/30/15 04:20 PM
11/30/15 04:20 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The part number 2944450 is the easiest, but it is not on early wheels. As posted it is a stepped down 15" ring on a 14" center. The date should be stamped next to the valve stem. Also the pentastar.
The ring should be marked 15x7 J and should also have a date.
Re: What are the correct wheels for 70 V code cuda? [Re: Morty426] #1960819
12/01/15 10:56 AM
12/01/15 10:56 AM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Thanks Guys! Now the quest begins & with my budget it may take some time!
Re: What are the correct wheels for 70 V code cuda? [Re: GTS440] #1960835
12/01/15 11:18 AM
12/01/15 11:18 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
If you decide not to take the $3K-$4K plunge for the correct 450 wheels seek out a set of 3766075 15x7 rims. They look similar and can be had for $250-$400 for all 4 of them.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: What are the correct wheels for 70 V code cuda? [Re: GTS440] #1961161
12/01/15 06:12 PM
12/01/15 06:12 PM
USA
vette1986 Offline
vette1986  Offline
USA
I think I have an extra set of 2 in storage that I don't need anymore as my v code cuda is a 14 inch wheel car based on the sticker in the door jamb. I think they are 450's?? They have a little rust right around the end of the part # so the last 3 digits are rusty and I can not make it out clearly. I have not dismounted them and blasted them but I think it will blast off as it is surface rust. PM me if you have any interest.
Plus let me know guys if you can tell off the pics if they are 450's. Thanks up
Too Many Projects!!
Re: What are the correct wheels for 70 V code cuda? [Re: vette1986] #1961166
12/01/15 06:18 PM
12/01/15 06:18 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, the 6/9/70 dated one shown is a "450" wheel, what's the date on the other one?
Re: What are the correct wheels for 70 V code cuda? [Re: 6bblgt] #1961172
12/01/15 06:27 PM
12/01/15 06:27 PM
USA
vette1986 Offline
vette1986  Offline
USA
It is the same date
It is the same date. I don't have a pic of it but I remember checking them when I took them off and they were both the same date code.
Too Many Projects!!
Re: What are the correct wheels for 70 V code cuda? [Re: vette1986] #1961349
12/01/15 10:53 PM
12/01/15 10:53 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
I have passed your information to someone looking for those wheels.
1970 `cuda340 convertible 4-speed Rallye Red with Red interior cudaized.com 1970-71 Plymouth and Dodge E-Body Convertible Registry ebodyconvertibleregistry.com /////AMG
Re: What are the correct wheels for 70 V code cuda? [Re: GTS440] #1961608
12/02/15 10:39 AM
12/02/15 10:39 AM
uk
TiMopar Offline
TiMopar  Offline
uk
The wheels coded 3580070 from 72-up are identical in appearance to '450's...
Re: What are the correct wheels for 70 V code cuda? [Re: cudaized] #1961610
12/02/15 10:47 AM
12/02/15 10:47 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
[/quote]
I have passed your information to someone looking for those wheels. [/quote]
I sold a mint pair of 6/9/70 earlier this year, it will be nice to see him complete the set. I have since ran across one more date afew weeks earlier...
Tom
70 Challenger RT/SE project - need NOS pillar emblems $$ LMK
Re: What are the correct wheels for 70 V code cuda? [Re: GTS440] #1961632
12/02/15 11:37 AM
12/02/15 11:37 AM
Canada
Maxwellwedge Offline
Canada
I assume you know it was a steel wheel/doggie car by way of your broadcast sheet? What codes are on it?
Re: What are the correct wheels for 70 V code cuda? [Re: Maxwellwedge] #1961666
12/02/15 12:10 PM
12/02/15 12:10 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Yes coded on BS for poverty caps. I'll try to remember to look at the BS tonight & let you know the code. GTS
Re: What are the correct wheels for 70 V code cuda? [Re: vette1986] #1961828
12/02/15 04:12 PM
12/02/15 04:12 PM
NJ
BldMnyCuda Offline
BldMnyCuda  Offline
NJ
Interested in these wheels. Call me at (609)709-9083. Thanks.
Re: What are the correct wheels for 70 V code cuda? [Re: vette1986] #1962603
12/03/15 06:34 PM
12/03/15 06:34 PM
NJ
BldMnyCuda Offline
BldMnyCuda  Offline
NJ
They sure look like legit 450s and the 6 9 70 date code would be right but you really need to look closely at the part # over the valve stem to be sure. I am interested if you still have them. thanks.
Re: What are the correct wheels for 70 V code cuda? [Re: Maxwellwedge] #1962658
12/03/15 08:21 PM
12/03/15 08:21 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
The tire code on the BS is U82
Wheel: road:28 color:fc7 spare:81
Wheel covers:88
Re: What are the correct wheels for 70 V code cuda? [Re: GTS440] #1962661
12/03/15 08:31 PM
12/03/15 08:31 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Wheel covers:88
450 steel wheels painted FC7 and a space saver spare
Re: What are the correct wheels for 70 V code cuda? [Re: GTS440] #1963019
12/04/15 11:10 AM
12/04/15 11:10 AM
Canada
Canada
And...... 88 ....doggies :^)
