Oil Filter mount question?
#1957844
11/25/15 07:19 PM
11/25/15 07:19 PM
Posts: 6,130 Melbourne , Australia
LA360
I have a few questions in relation to the oil filter mounting on a Gen III Hemi engine.
What size in the thread into the block for the oil filter fitting?
what diameter oil filter is used?
Can someone post a pic of the oil filter area ?
Cheers
Alan Jones
Re: Oil Filter mount question?
[Re: RylisPro]
#1957917
11/25/15 09:57 PM
11/25/15 09:57 PM
LA360
What is the thread in the block? So the adapter is either 3/4" UNF or M22, what's the thread that screws into the block?
Cheers
Alan
Alan Jones
[Re: biff426]
#1958380
11/26/15 03:10 PM
11/26/15 03:10 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
You can buy the 3/4 nipple and screw it right in then the filter options are a lot better you can use a larger filter to add oil capacity That is what I have mocked up to use a System 1 filter with the truck angle mount.
"Just a Bracket car dressed up like a streetcar"
[Re: LA360]
#1958405
11/26/15 04:06 PM
11/26/15 04:06 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
If you use a /6 K member and fab your own mounts, you can put it in the stock position. I went ahead and put on a remote adapter with a thermostat and cooler out of road course paranoia.
Mopar to the bone!!!
[Re: 72Swinger]
#1958499
11/26/15 08:54 PM
11/26/15 08:54 PM
LA360
I'm asking because I've been asked to make a remote oil filter kit for a Gen III engine. I make them for LA engines currently, just looking at what changes I'd have to make to adapt my current kit to the Gen III stuff. I may have to pick up the nipple from somewhere and go from there. I've been looking around for a Gen III engine to buy, but it will have to wait until after the holidays.
Cheers
Alan
Alan Jones
