426 Hemi rocker shaft bolt length #1956908
11/24/15 02:14 AM
11/24/15 02:14 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi everybody. Does anybody know how long are the rocker shaft bolts on a 426 Hemi? I know there 3/8x16 but how long are they?
Thanks, Troy
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: 426 Hemi rocker shaft bolt length [Re: Troy] #1956975
11/24/15 09:22 AM
11/24/15 09:22 AM
P
PasiR Offline
PasiR  Offline
P
StageV has 1 3/4".
Re: 426 Hemi rocker shaft bolt length [Re: PasiR] #1957209
11/24/15 06:12 PM
11/24/15 06:12 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
You could take a bolt that's way to long, run it down till it bottoms out, mark on the shank with a thin permanent marker or scribe with washer in place. Check the other holes also with that mark, and then give your self a little leeway so the bolts wont bottom out. Another way to look at it, you would want at least 3/8" minimum thread engagement into the stand I would think. You might check on ARP's site and see what they list it as too.
No help here,...I run allen head studs in a Stage V head with al stands. 3 studs would hit stock valve covers in the #1 & #8 cyl area baffles because the studs stick up higher than the nuts. Even though I shaved those 6 studs I ended up with Stage V covers which clears.
Re: 426 Hemi rocker shaft bolt length [Re: Troy] #1957244
11/24/15 07:07 PM
11/24/15 07:07 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Thanks everybody. 👍😀
