OK! No more BS. Time to start working.
#1955519
11/21/15 08:34 PM
11/21/15 08:34 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
After my mother-in-law passing away this week, I decided that life is too short to procrastinate on everything you want to do. So the garbage got thrown out, everything else got put in a spot, the Cuda finally saw daylight after, I don't know how long, bath and up on jack stands. Tomorrow, measure, measure, measure, disassemble and measure.
Re: OK! No more BS. Time to start working.
[Re: sgcuda]
#1955526
11/21/15 08:48 PM
11/21/15 08:48 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I wondered what happened to that car. Glad you're back on it.
[Re: sgcuda]
#1955540
11/21/15 09:07 PM
11/21/15 09:07 PM
sgcuda
Measured frame rail widths. Front rails are 33" on the inside where the notch is to clear the header tube. Rear backhalf is 31" on the inside. Headers are 28" on the outside. Going to cut right in front of the notch and go straight back to the ladder bar crossmember, and stay 1/2 above the rocker sill (stock rails are about 1" lower than rocker sill from front wheel well opening to transmission crossmember). New trans crossmember and driveshaft loop crossmember will get added. Old loop member is welded in and creates issues when removing trans. 4 speed input is very long.
[image][/image]
[Re: sgcuda]
#1955633
11/22/15 12:35 AM
11/22/15 12:35 AM
Posts: 1,290 Tucson AZ,
MadMopars
Tucson AZ,
Sorry to hear about your mother-in-law. The car looks like a fun project, everyone else's stuff always looks more fun than mine though. Is that the same car that's in your signature pic? If so, what was your reason for tearing it down in the first place?
[Re: sgcuda]
#1955667
11/22/15 02:16 AM
11/22/15 02:16 AM
sgcuda
Well, I got in a bit of trouble some years ago, so I sold the car to a co-worker. After sanding it down and sitting out in the weather for 2 years, I was able to buy it back. Not quite the same shape as before, but at least I got it. I wasn't happy with the first attempt, homemade front end, so that got torn out. Engine in avatar was almost done, until I got some new ideas.
[image][/image]
[Re: sgcuda]
#1955984
11/22/15 06:33 PM
11/22/15 06:33 PM
sgcuda
But serious damage was just around the corner on the right side. Something weird causing the right axle shaft to move around. The inside of the drive studs started to cut through the wheel cylinder. Could have been nasty.
[image][/image]
[Re: sgcuda]
#1955988
11/22/15 06:38 PM
11/22/15 06:38 PM
sgcuda
Measured both axles flange to retainer, drivestud distance, checked for differences in wheel cylinders, mounting studs for retainer, backing plate depth. Checked axle bearing registers, heights, etc. The only thing I see is that there is a grease line around the seal on the right bearing where it oozed out a little. The left bearing is sparkling clean. Could the rollers in the bearing be worn? It had to move over .100". I didn't notice any motion when I tore it down. Going to call Moser during the week to see if they could shed some light.
[image][/image]
[Re: sgcuda]
#1956419
11/23/15 12:43 PM
11/23/15 12:43 PM
Posts: 13,356 Marion, South Carolina [><]
an8sec70cuda
Glad to see you're getting it out and working on it again Kenny! Sorry about your MIL...tell Diane I'll be thinking about her. On the axle...take a good look at the machined surface the bearing is pressed onto. It must be worn and letting the axle/bearing slip in and out...IF the bearing itself is still in good shape.
[Re: sgcuda]
#1956754
11/23/15 10:27 PM
11/23/15 10:27 PM
sgcuda
Thanks, Chip. Nope. Bearing isn't walking on the axle. I think the inside step on the race is worn. Changing both axle bearings.
[image][/image]
[Re: sgcuda]
#1958522
11/26/15 09:54 PM
11/26/15 09:54 PM
sgcuda
Figured out axle problem. Housing was deeper than bearing thickness, plus gasket thickness, plus backing plate thickness, allowed for .150" motion. Will fabricate up shims.
Ran a ride height line along the side of the car and set the rear slicks in place. Setting up for about 4" ground clearance in the front and 6" in the rear. Significantly lower than before. For the first time, the lower ladder bar will actually be able to adjust above and below parallel to ground.
[image][/image]
[Re: sgcuda]
#1958554
11/26/15 10:56 PM
11/26/15 10:56 PM
sgcuda
Thanks, Neil.
They look as good as the chassis engineering piece, minus the coil over brackets. I'll give them a call and see if they have a bracket upgrade.
[image][/image]
[Re: sgcuda]
#1959380
11/28/15 07:52 PM
11/28/15 07:52 PM
sgcuda
So, I have come to the conclusion that when in your 20's, since priorities are sex and alcohol (and not necessarily in that order) maybe welding should be left to the more experienced. Finally repaired/redone/finished the parachute mounting crossmember. My level of expertise at that time was "Make sure the snow plow doesn't fall off the front of the boss's tow truck!". I'm getting close, Chip. Take a good look at the pic. Your going to be seeing this view a lot this summer.
[image][/image]
[Re: sgcuda]
#1960284
11/30/15 04:09 PM
11/30/15 04:09 PM
an8sec70cuda
I should hope so Kenny, but remember mine looks the same as yours. Only you can see my mufflers, small tires, and license plate from the rear. Just let me know when you're ready to TRY.
[Re: sgcuda]
#1963893
12/05/15 06:48 PM
12/05/15 06:48 PM
sgcuda
I had the motor pro built while I did the chassis and suspension back in the late 80's. Not knowing anything about coil overs, I went through an extreme learning curve, including 1 time veering off the track on a 2-3 full power shift. Didn't wreck, minor damage, but knocked out the mirrors in the headlight buckets. Never got around to putting them back after I sorted out the suspension... until now.
[image][/image]
