Re: young mopar fan building a 360 need help
[Re: smallblock666]
#1952370
11/16/15 03:52 PM
11/16/15 03:52 PM
Triple Threat
Renton Washington
KB107 is a popular piston option, make sure the piston to wall clearance is correct. http://www.summitracing.com/parts/uem-kb107-030Thinnest affordable head gasket you can find http://www.summitracing.com/parts/mrg-1121g/overview/make/dodgeCam will depend on if you want to stay hydraulic flat tappet or if mechanical is an option. For a basic street/ strip ride something around 230-240@.050 duration and .500 lift is good. If you're staying stock rockers i'd pick a hyd flat tappet cam around 230/230@.050 and .480 lift Dual plane, edelbrock RPM or equivalent. 3.91 or 4.10 is fine. Opt for more stall rather than less. I'd try for 4000 stall. I daily drove my dart for years with a 4700 stall 9.5" PTC converter behind the 340, dont be scared, it only stalls that high with your foot to the floor.
[Re: smallblock666]
#1952495
11/16/15 08:12 PM
11/16/15 08:12 PM
Posts: 447 NJ
JCCuda
NJ
Here are two 360 combos that i have run. Very similar cast piston short blocks but different hydraulic cam and different converters. The bigger cam as expected needed a looser converter. If I was going to do the 360 in the Duster over I would stick to a 224@.050 cam with a 108 or less lobe separation like I had used in the Valiant but with a looser converter then the Valiant.The other difference is transmissions (727 Duster) (904 Valiant). Below I copied and pasted 2 of my previous post.
This is my Duster, Finally got the Duster into the 11's. After I lost first round cause I sucked driving the finish line I decided to take some weight out of the car and see if I could get into the 11's. I weighed the car before the 1st time shot 3,495lbs. with me in the car. 1st. t/s the car went a 12.182/109.57 2nd. t/s 12.180/109.79. 1st. round 12.137 on the brakes was going a 12.12 something going off the 1000' so I didn't kill much. As I mentioned I sucked driving the finish line cause I was .004 on the tree. Anyhow since I had lots of time to kill I took out the spare tire and the 50lb. plate that I had under the tire along with all the hold down hardware and went up and made a t/s the car went 12.022/110.81 with a so far best 60' of 1.640 I weighed the car after the pass 3,390lbs. Next I took out the pump spray bottle from behind the seat and a small toolbox and I cooled the car down to 105 degrees go in the water at 125* and the line at 135* the car went 11.943/111.80 and 1.634 60' weight after that pass was 3,370. It's not bad for a cast flat top 360, 9.9 compression, 232/237@.050 hyd., mild pocket ported 2.02/1.60 J heads, LD340 vac.750, heddman 1-5/8" header, 3" summit exhaust with dynomax ultraflows, point's dist. with a super coil, 3.91 gears, 255/60/15 M/T drag radials, 727 trans.. It gets driven on the street but not to far because I have a water pump drive on it and an 8" converter right now. Any suggestions on making it go faster without spending money are welcome.
This was my Valiant, My 360 started as a .040 over Napa rebuilt short block. I took it apart to check everything. I had the block decked (deck .015 head 63cc., gasket .028, compression 10.51)reversed the cast dished pistons on the rods and put in good rod bolts and had the rods resized. I put in an old Manley cam that I had. 443 lift 224@.050 I don't remember the lobe seperation but I think it was around 108. I used J heads pocket ported with 2.02 int. valves and 273 adj. rockers an LD340 intake with a 1" 4 hole spacer and a Vac. 750. For exhaust I used heddmen 1 5/8" headers, 3" exhaust with ultra flows ending at the axel. I used a 904 with a Dayco 2,400 stall converter and an 8 3/4 with 3.91's the slicks were 8"x 26"x 14". Suspension consisted of 6yl. bars and comp. eng. adj. shocks in the front and 002/003 superstock springs with Mopar perf. 50/50 xtra long shock in the rear. The car was a 70 Valiant 4 door it weighed 3,320 with me in it. With an electric water pump drive, 5/16" fuel line with holley mech. fuel pump and a homemade fresh air intake (dryer hose and a dual snorkle air cleaner)the best run was 11.96/113 but it typically went 0's and teen's in decent air at Atco and E-Town. Typical 60'was low 1.70's. With a looser converter maybe around 3,500 stall it probably would have gone 11.70's or 80's.
[Re: smallblock666]
#1952776
11/17/15 02:43 AM
11/17/15 02:43 AM
Superfreak
Superfreak
If you have some extra cash you can consider stroking it.
[Re: smallblock666]
#1952888
11/17/15 11:56 AM
11/17/15 11:56 AM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
There's a reason why those cast Eagle stroker cranks are on clearance. Just sayin'
1970 Duster 340 clone
[Re: BrianT]
#1952937
11/17/15 12:53 PM
11/17/15 12:53 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
There's a reason why those cast Eagle stroker cranks are on clearance. Just sayin' Buy one, get two.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#1953163
11/17/15 06:17 PM
11/17/15 06:17 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
There's a reason why those cast Eagle stroker cranks are on clearance. Just sayin' Buy one, get two. The cast cranks are not as strong as the forged ones, and I have seen two break, but those were in low 11 second, high 10 second cars. I don't think the crank is likely to break running under 400 HP?
[Re: smallblock666]
#1953450
11/18/15 01:47 AM
11/18/15 01:47 AM
Posts: 883 Affton MO
qwkmopardan
Affton MO
Cheap 360 for heavy car recipe: KB107 or KB190 pistons, w/.030 top ring gap Scat SCA-26123 rods Stock crank turned .011, .021, or .031 U.S. as needed, and balanced Rebuilt factory heads w/$500-$600 port job-- avoid 308 castings as pushrod hole is huge and limits pushrod pinch porting. Racer brown ST-21 Camshaft--254* at .050 and .520" lift 273 Rocker arms Comp 7822-16 push rods Comp 995-16 springs performer rpm air gap intake Holley 750 vac sec. carb Cometic C5633-027 head gaskets if pistons are below deck, .040 if zero deck, expensive but re-usable and wont blow. Use ARP head bolts 9 1/2" or 10" tq conveter-Dynamic or Turbo-Action 4.10 gears-- you may want to find a 9-1/4 rear-end from a magnum gt or 79 "300". 8 1/4 will hold up for a while. Would be enough engine for mid 12s 1/4 mile in 4200lb car or truck-- It will think it's a big block. 79 "300"--360/442 c.i. sm block--587 production heads--full exhaust to the rear bumper with 4 mufflers--4150 lbs. on the scale at LORP in Indy--11.40s at 117mph 1/4 mile--7.20s at 94mph 1/8th--1.57 60ft--13 mpg on highway during Dragweek 2015--There is more in the 442 c.i. engine--had no time to tune as it got started for first time 3 days before dragweek and got wrecked in Chicago--finished dragweek but parked until fixed. Old 408 engine-- new 442 looks exactly the same except clean
[Re: smallblock666]
#1954424
11/19/15 06:34 PM
11/19/15 06:34 PM
DaytonaTurbo
Manitoba, Canada
If I were you, I would junk the 318 and the 360. Find a 90's 5.2 or 5.9 magnum out of a pickup. The magnum engine with have decent compression pistons, moly rings, and heads that flow better than your old junk. 300-500 bucks should be able to get you a good runner you can just drop in. I wouldn't even open it up, other than to change the intake manifold if you want to go carbed. If you check on ebay and the mustang forums, you can find good deals on new and used centrifugal superchargers for 5.0L mustangs. Toughest part would be fabricating your supercharger mounting bracket. Put it all together with an otherwise stock engine and you should be looking at 350-400hp. Add headers and a cam upgrade and I would expect 450hp. Best part is if you blow it up you go find another donor engine to drop in.
I would try to find a complete 2wd 92-95 ram truck or van as a complete donor, because the overdrive transmission would be a good score/upgrade for your car. Throw your old junk in the box after and send the shell off for scrap.
[Re: DaytonaTurbo]
#1954640
11/20/15 12:27 AM
11/20/15 12:27 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I would try to find a complete 2wd 92-95 ram truck or van as a complete donor, because the overdrive transmission would be a good score/upgrade for your car. Throw your old junk in the box after and send the shell off for scrap. Dakota guys are putting down 550whp with stock 360's and turbos tuned by flyinryan tuning.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
