Small block copper oil pump gasket #1953338
11/17/15 11:39 PM
11/17/15 11:39 PM
Newark, OH
Hunted Duck Offline OP
Newark, OH
Has anybody ever used one? Are they better than the paper gasketd that come with a oil pump. Got the motor apart and seen these and wonder if I should try one.
Re: Small block copper oil pump gasket [Re: Hunted Duck] #1953345
11/17/15 11:50 PM
11/17/15 11:50 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I just used some anarobic sealer. No issues.
Re: Small block copper oil pump gasket [Re: Hunted Duck] #1953392
11/18/15 12:46 AM
11/18/15 12:46 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I always just use anaerobic sealer... Works like a charm.
Re: Small block copper oil pump gasket [Re: dizuster] #1953410
11/18/15 12:59 AM
11/18/15 12:59 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I made a copper one so far so good
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Small block copper oil pump gasket [Re: Hunted Duck] #1953694
11/18/15 02:16 PM
11/18/15 02:16 PM
Newark, OH
Newark, OH
Thanks for the input guys.
Re: Small block copper oil pump gasket [Re: Hunted Duck] #1953800
11/18/15 06:05 PM
11/18/15 06:05 PM
dogdays Offline
dogdays  Offline
No gasket at all, stock.
R.
Re: Small block copper oil pump gasket [Re: rickraw] #1954168
11/19/15 07:12 AM
11/19/15 07:12 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Ding-ding, winner.
"I think its got a hemi"
Re: Small block copper oil pump gasket [Re: Hunted Duck] #1954187
11/19/15 10:41 AM
11/19/15 10:41 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've always used a thin paper gasket, on this build I used nothing.
Re: Small block copper oil pump gasket [Re: Hunted Duck] #1954338
11/19/15 04:02 PM
11/19/15 04:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I pretty much always use no gasket, if they are not flat enough to seal up you got an issue you need to fix. The factory never used them. One less gasket or sealant to blow out into the pan. If it leaks it would be very tiny and not worth any fuss. One time I had one where it looked like they had an extra dull cutter machine it and I used a very thin coat of right stuff, I think it would have probably been fine with out.
