How would u move a lost key truck ? #1952699
11/17/15 12:41 AM
11/17/15 12:41 AM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Buying a truck off a friend of mine. 92 Dodge 4x4. been sitting for years. he lost the keys. Some what's the best way to get this thing on my trailer? pop the transfer case in neutral is how I'll get it to roll.but now how do I steer it?? thought I would tear column apart but didn't really want to waste a lot time. Any suggestions?? automatic on the column. thanks
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: How would u move a lost key truck ? [Re: hulmule] #1952710
11/17/15 12:53 AM
11/17/15 12:53 AM
I'm assuming the door locks take the same key as the ign (if so) you might pull a door panel & take the lock cyl out & take it in & have a key cut for it. either that or pull the st wheel to get to the innards underneath & unlock the steering
Re: How would u move a lost key truck ? [Re: hulmule] #1952719
11/17/15 01:02 AM
11/17/15 01:02 AM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
thought about tearing column apart but gets dark fast. trying to do after work. weather changing and this week is a good week in northeast ohio. something fast but i guess it my last resort. pop of steering rod at steering box ??
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: How would u move a lost key truck ? [Re: hulmule] #1952734
11/17/15 01:24 AM
11/17/15 01:24 AM
yes if you disconnected the st col down at the st box that would work
Re: How would u move a lost key truck ? [Re: hulmule] #1952754
11/17/15 01:44 AM
11/17/15 01:44 AM
ky.
K
kenworth_goose Offline
K
ky.
Pull the switch out of it. Might take 3 minutes if your slow. All you need is a small set of torx screw drivers and a small set of tamper proof torx screw drivers. Pull the tilt handle if it has tilt, 2 torx screws that hold the bottom cover on, then pull the top piece off and then the tamper proof torx screws and it out. Reach in a turn with a screw driver
Re: How would u move a lost key truck ? [Re: hulmule] #1952780
11/17/15 02:50 AM
11/17/15 02:50 AM
Northeastern PA
Fanning Offline
Fanning  Offline
Northeastern PA
Bring your friend that owns the truck with you to the local Dodge dealership parts department. Have him bring the title or registration to the vehicle along with personal ID. Have the key cut to code based on the vin.
Re: How would u move a lost key truck ? [Re: kenworth_goose] #1952782
11/17/15 03:00 AM
11/17/15 03:00 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Yuuuuup!!!!!
Re: How would u move a lost key truck ? [Re: hulmule] #1953029
11/17/15 02:23 PM
11/17/15 02:23 PM
crlush Offline
crlush  Offline
My buddy bought alot of cars at auctions with no keys and just paid a locksmith to make one, i think he said it cost around 75bucks.
Re: How would u move a lost key truck ? [Re: crlush] #1953032
11/17/15 02:26 PM
11/17/15 02:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It cost around $25 to have the Dodge dealer cut a key with proof of ownership.
- Stu Harmon
Re: How would u move a lost key truck ? [Re: hulmule] #1953045
11/17/15 02:40 PM
11/17/15 02:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
With a truck, trailer and winch, you really shouldn't need a key. With a tow strap you can drag the truck where it needs to be, then winch it up the trailer. Have used plywood boards and a floor jack to lift vehicles to pivot them sideways. Have used wood planks greased up with dish soap to slide tires to pivot vehicles. Lots of ways it can be done.
A socket set, small compressor and an air hammer and I suppose you could disconnect the steering shaft if you wanted to.
Re: How would u move a lost key truck ? [Re: DaytonaTurbo] #1953046
11/17/15 02:46 PM
11/17/15 02:46 PM
sounds like you are wanting to get it to its new home ASAP. If it is on concrete & you have some skates that'd work or at least jack up the front wheels off the ground each time you need to move the wheels (If you do disable the st col shaft) several times as you tow it back & forth till you can get it lined up enough to be towed. If there ain't no rush then I would do the key deal as said cuz you're gonna need that sooner or later. I hope its a good deal for you
Re: How would u move a lost key truck ? [Re: hulmule] #1953125
11/17/15 04:57 PM
11/17/15 04:57 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You should have read the FIRST response. Take the door panel off and pull the lock cylinder.
Re: How would u move a lost key truck ? [Re: hulmule] #1953127
11/17/15 05:01 PM
11/17/15 05:01 PM
ky.
K
K
ky.
Pulling the switch is easier than the door panel!
Re: How would u move a lost key truck ? [Re: hulmule] #1953137
11/17/15 05:36 PM
11/17/15 05:36 PM
AndyF Offline
AndyF  Offline
With the older trucks you just disconnect the wiring harness that goes up the steering column and then plug in a new harness with a cylinder. I used to have a spare column harness with a cylinder and key and I could start up any truck in just a few seconds by plugging in my spare harness.
Re: How would u move a lost key truck ? [Re: hulmule] #1953383
11/18/15 12:36 AM
11/18/15 12:36 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I just removed the door lock and took it to the locksmith, $16.00 later I had a ignition key that worked.
