Cheap 360 for heavy car recipe:
KB107 or KB190 pistons, w/.030 top ring gap
Scat SCA-26123 rods
Stock crank turned .011, .021, or .031 U.S. as needed, and balanced
Rebuilt factory heads w/$500-$600 port job-- avoid 308 castings as pushrod hole is huge and limits pushrod pinch porting.
Racer brown ST-21 Camshaft--254* at .050 and .520" lift
273 Rocker arms
Comp 7822-16 push rods
Comp 995-16 springs
performer rpm air gap intake
Holley 750 vac sec. carb
Cometic C5633-027 head gaskets if pistons are below deck, .040 if zero deck, expensive but re-usable and wont blow. Use ARP head bolts
9 1/2" or 10" tq conveter-Dynamic or Turbo-Action
4.10 gears-- you may want to find a 9-1/4 rear-end from a magnum gt or 79 "300". 8 1/4 will hold up for a while.
Would be enough engine for mid 12s 1/4 mile in 4200lb car or truck-- It will think it's a big block.
79 "300"--360/442 c.i. sm block--587 production heads--full exhaust to the rear bumper with 4 mufflers--4150 lbs. on the scale at LORP in Indy--11.40s at 117mph 1/4 mile--7.20s at 94mph 1/8th--1.57 60ft--13 mpg on highway during Dragweek 2015--There is more in the 442 c.i. engine--had no time to tune as it got started for first time 3 days before dragweek and got wrecked in Chicago--finished dragweek but parked until fixed.
![](http://i151.photobucket.com/albums/s153/johnsmith_45/IMG_1754-1.jpg)
Old 408 engine-- new 442 looks exactly the same except clean
![](http://i151.photobucket.com/albums/s153/johnsmith_45/300engine_zps33ac44a3.jpg)
