Browell Bell Housing Alignment Tool
#1952326
11/16/15 02:43 PM
11/16/15 02:43 PM
Posts: 5,134 Las Vegas, NV
Tom_440
Las Vegas, NV
I ordered this tool to check the bellhousing alignment on my Lakewood. The folks at Browell's probably don't sell a ton of these for Mopars so I had to gather a couple measurements before I could place my order. Figured I'd post about it in case someone else needs the info... ScottSmith_Harms did a great job posting images and information about the tool and the bellhousing opening measurements here (Thanks Scott!): https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/8208101/site_id/1The bellhousing opening is either 4.850" or 4.685" The part of the Browell tool that bolts to the crankshaft is one of two sizes, either 2.160" or 2.043". The measurement is made by measuring the outside diameter of the "ring" at the end of the crankshaft. I have a 440 crank which measured at 2.160.
Re: Browell Bell Housing Alignment Tool
[Re: Tom_440]
#1969233
12/14/15 12:29 AM
12/14/15 12:29 AM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
I received the tool quickly, but its taken a while to get under the car. The bowling pin part of the tool fits snug on the torque converter register. However, the 4.850 "ring" size that I gave to Browell's is too big for the opening in my bellhousing. Looks like it may actually be 4.805" instead. To be continued... Yep. I measured mine with two different calipers and came up with 4.80 as well.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
