Will 17" Mustang GT wheels fit on a SRT-8 Challenger? #1951396
11/15/15 02:43 AM
11/15/15 02:43 AM
Western Ohio - formerly Southe...
hemid68 Offline OP
hemid68  Offline OP
I have a chance to buy some 17" Weld RTS wheels, which were on a 2014 Mustang GT, for my 2009 SRT-8 Challeneger. Will they work?
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: hemid68] #1951936
11/15/15 10:16 PM
11/15/15 10:16 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I looked at a bolt pattern website, it didn't list a 2009 challenger but it did list a 2009 Charger. And it didn't list a 2014 Mustang but it did list a 2011 Mustang so these results may be wrong but this is what it said:
2009 Dodge Charger
Bolt Pattern (in):
Bolt Pattern (mm):
Offset Range (mm):
Front Center Bore (mm):
Rear Center Bore (mm):
Stud_Size:
5x4.53
5x115
12 to 22
71.5
71.5
14x1.5
2011 Ford Mustang
Bolt Pattern (in):
Bolt Pattern (mm):
Offset Range (mm):
Stud_Size:
5x4.50
5x114.3
34 to 45
70.5
70.5
12
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: hemid68] #1952179
11/16/15 04:51 AM
11/16/15 04:51 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Why go from a stronger, better looking 20" wheel to a smaller 17"?????
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: hemid68] #1952190
11/16/15 08:59 AM
11/16/15 08:59 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
A 17" Weld RTS is a good looking wheel, and if he's going for the look of a drag wheel he won't be able to do that with 20" wheels.
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: hemid68] #1952194
11/16/15 09:42 AM
11/16/15 09:42 AM
places
79powerwagon Offline
places
I don't think that site is right. Mopar still uses 4.5 bolt circle (114.3mm), right?
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: Kern Dog] #1952198
11/16/15 09:53 AM
11/16/15 09:53 AM
the house on the left.
cogen80 Offline
cogen80  Offline
because its his car and thats what he wants to do. seems simple enough to me.
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: hemid68] #1952247
11/16/15 12:15 PM
11/16/15 12:15 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Bolt patterns may line up, but if its an SRT-8, the Mustang wheel may not clear the brakes.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: cogen80] #1952262
11/16/15 12:57 PM
11/16/15 12:57 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Agree, but there will be a lot of snickering when people walk by a Challenger and see Mustang wheels on it. Just hope he's ready to deal with that.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: Centerline] #1952266
11/16/15 01:03 PM
11/16/15 01:03 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
This tells me that you have no clue what a Weld RTS wheel is.
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: hemid68] #1952294
11/16/15 01:53 PM
11/16/15 01:53 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I used some older mustang wheels on my car-'68 Barracuda, the backspacing caused me to get some custom studded wheel adapters for the rear. The front I need to cut the center register on the rotors, just a few thou. The center caps stuck out past the face of the wheel, I've worked out a solution, I'll post some pics later, but it is a compromise and I'm not sure it will apply to the Weld wheel. BTW, I really like those Weld RTS wheels up The best bet is to mount them up before you buy or carefully measure YOUR car, these are mass produced and tolerances can and will cause problems. twocents
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: hemid68] #1952319
11/16/15 02:38 PM
11/16/15 02:38 PM
AndyF Offline
AndyF  Offline
No, they won't fit. Bolt pattern isn't correct, back spacing is wrong and they are too small to fit over the brakes.
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: ProSport] #1952693
11/17/15 12:35 AM
11/17/15 12:35 AM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Oops! Missed the fact these were aftermarket parts.
Centerline
Re: Will 17" Mustang GT wheels fit on a SRT-8 Challenger? [Re: hemid68] #1952726
11/17/15 01:14 AM
11/17/15 01:14 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Lol, no problem.
