Absolutely it will
Jack the car up and put it on jackstands so you can remove the wheels and measure the front toe in and then the back toe out, if it is more than 1/8 inch difference front to back you have a bent housing
I use two carpenter squares or any two true straight edges and a measuring tape to measure 15 inches out from the center of the axles on the front towards the front of the car and then staright back, you should also try and do the same measurement straight up and then down the same distances from the center of the axles to see if it is bowed up and down also
Let us know what you find, HP can and will make the 60 ft change also as well as tire age and track prep
