Re: Which GEARS/TIRES do you use ? [Re: Cab_Burge] #194981
01/17/09 02:53 PM
01/17/09 02:53 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
3400 lb Duster with driver, 3:91 gears, 315x60x15 ET Street Radails, 10:34 ET at 128.6 mph. I have used 3:73, 4:10 and the 3:91 in the same car with almost identicle results The motor is 518 C.I. pump gas with some good parts so that can make a difference, 700+ hp and 740+ ft lbs torque last time on the engine dyno
like cab i just switched to M/T ET streets 295-65-15 though. with 4.10 gear i was using M/T 28/10.5 slicks. 1.42 60' 4,000 lb car&dr.
Re: Which GEARS/TIRES do you use ? [Re: blownzoom440] #194982
01/17/09 03:07 PM
01/17/09 03:07 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Last season I ran the Hoosier 30x10.5 92.5 cir Radial slicks with a 4:30 gear. Best 60' with those was a 1.42. This season I will be running M/T 29.5x10.5 non "W" slicks.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Which GEARS/TIRES do you use ? [Re: dart_73_br] #194983
01/18/09 01:42 PM
01/18/09 01:42 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
295-65 ET Street radials (30" tall), 4.10 gears. 3800#, 9.54 at 140.4 mph w/ a 1.32 sixty foot. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which GEARS/TIRES do you use ? [Re: an8sec70cuda] #194984
01/18/09 02:18 PM
01/18/09 02:18 PM
LEBANON;PA
daron Offline
daron  Offline
LEBANON;PA
i run 4:10 and 28x13.50 tire on my duster and i drive it on the street 1.46 sixty foot times
