Re: Advice Needed on a New Stroker [Re: JACK1440] #1948228
11/09/15 06:30 PM
11/09/15 06:30 PM
Farmington Hills, Mich
Chuck@Best_Machine Offline
Here one of many we have done.
295 CNC SR Heads
279 @ .050 Roller
1.6 Rockers
12 to 1
VP 110 Fuel
1050 4150
This is a mild Road Race Engine
Link ; https://www.facebook.com/media/set/?set=a.406708556051500.108982.135175363204822&type=3
Re: Advice Needed on a New Stroker [Re: JACK1440] #1949381
11/11/15 01:15 PM
11/11/15 01:15 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Our motor that just let loose was a 500" 440. With this cam .75/.74 286/300 112 - 13.2-1 comp and single 1050 dom. It ran 9.84 car weighed 3450 with me. It shifted 7000 and seemed to be done around 7400. If I could do it again I would have bought a bigger head but.... their mine now. Nick Wilson's thought process was to hang the exhaust valve open a long time compensate for the small exhaust port. As I believe Chuck said. The 540 would probably run ok with the ez's and maybe someday I can upgrade to a bigger head with the same short block. I have a chance to build the 572 cheaper because of available parts but, I'm afraid it'll be a big dummy. lol
Re: Advice Needed on a New Stroker [Re: JACK1440] #1949977
11/12/15 01:44 PM
11/12/15 01:44 PM
gregsdart Offline
gregsdart  Offline
If you go after market block, consider the weight if you are looking at an iron block. If you go aluminum, it may be easier move weight forward than moving it back for too much weight up front.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
