rebuilt 496 sounds like a diesel? Updated with video
#1944646
11/03/15 11:07 PM
11/03/15 11:07 PM
Posts: 1,707 Nebraska
70VcodeCoronetRT
Nebraska
Ok finally got the six pack tuned in and running on the idle circuit. But my concern is this 496 sounds like a diesel. I had the short block put together by a local shop. It is a mild .040 496 with a Mr Six Pack cam. Roughly 471 I 490 E hydraulic. Diamond dish pistons, eagle rods and crank. It doesn't sound like it's coming from the rocker area. I even pulled a valve cover and everything looked good. It sounds like from the block area. Under the intake maybe. Sounds like piston slap. Timing is 18 initial. And has 40lbs oil pressure at idle warm. With a standard oil pump. The motor doesn't miss or stumble at all. Seems to run good. Just sounds like it wants to fly apart. Any ideas before I pull it back out? Thanks
Re: rebuilt 496 sounds like a diesel? long
[Re: 70VcodeCoronetRT]
#1944672
11/03/15 11:24 PM
11/03/15 11:24 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
My guess would be piston rock. There's most likely not a whole lot of skirt in the bore relative to the pin at BDC. I've heard a few strokers that sounded like a coffee can full of rocks at idle. Don't know that I would be all that worried, but it's hard to say without actually hearing it in person. The "diesel" description is common with this issue, not necessarily a problem.
[Re: TRENDZ]
#1944674
11/03/15 11:26 PM
11/03/15 11:26 PM
moparpollack
Lil Herman
Lil Herman
85086
Yup sound like BDC piston rock.
#1944699
11/03/15 11:42 PM
11/03/15 11:42 PM
70VcodeCoronetRT
Nebraska
I have to work tomorrow. But I'll try and get a video up Thursday.
#1944854
11/04/15 04:19 AM
11/04/15 04:19 AM
Posts: 4,848 Memphis
HemiRick
Memphis
^^^^^I 2nd the above, a buddy of mine built a 383 w keith black pistons that were too loose and it sounds just like a diesel.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1944917
11/04/15 11:07 AM
11/04/15 11:07 AM
Posts: 3,916 usa
lewtot184
usa
^^^^^I 2nd the above, a buddy of mine built a 383 w keith black pistons that were too loose and it sounds just like a diesel. all those hypers are noisey when cold but if they're a couple thousands too loose then you really need to turn the radio up.
#1945205
11/04/15 08:05 PM
11/04/15 08:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
My Arias pistoned 400 rod, 3.75 stroke 400 sounded like that for 19 yrs. I finally traded it for a 6.1 Hemi. Piston slap ala mode. Goes away with RPM in my experience.
Mopar to the bone!!!
#1946364
11/06/15 04:12 PM
11/06/15 04:12 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Streetwize what cam is in that 517? What exhaust? Sounds awesome!
[Re: lewtot184]
#1946967
11/07/15 03:08 PM
11/07/15 03:08 PM
Posts: 996 Queens, New York
Harley
Queens, New York
doesn't sound much different than my 440 solid lifter, light piston, street engine. is some of that noise valve train related? what type of tappet? any oil restrictors? what rockers? Same here.
#1947056
11/07/15 06:25 PM
11/07/15 06:25 PM
Posts: 75,134 A Banana Republic near you.
JohnRR
Sheet from the machine shop shows a final oversize of 4.360. Using the Diamond 52417 piston. which is a 4.360 bore piston. That doesn't tell you what clearance he set it at .
#1947100
11/07/15 07:56 PM
11/07/15 07:56 PM
Posts: 712 California
BigDaddy440
California
My first 440 with KB hypers sounded like a diesel at Idle...I mean you could hear that sound a bit. I was told it was a common hyper piston sound. The engine is still running to this day after 15 years with no issues..street / strip.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
#1947410
11/08/15 09:55 AM
11/08/15 09:55 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Looks like .005 piston to wall clearance. If I'm reading his scribbles correct. Sounds on the loose side, but is a stroker so that might be normal (I have no experience with storkers yet) My memory is fuzzy after 25+ years but the TRW forged slugs in my 440 were set to 3 and 1/2. Motor has been together forever, buzzed to 7200 and hit hard with nitrous too. Cast pistons run tighter than forged as they expand less.
"I think its got a hemi"
#1947455
11/08/15 12:09 PM
11/08/15 12:09 PM
TRENDZ
Milwaukee WI
The issue is pistons are not the same diameter at the top as they are in the skirt. with a stroker, the skirt hangs out of the bore at BDC, and the piston is generally much shorter, the top of the piston fits the bore looser, and that is why it "rocks" at BDC.
