440 Thrust bearing problem #1943985
11/02/15 10:44 PM
11/02/15 10:44 PM
Colorado
Hem1orange Offline OP
Colorado
I'm rebuilding a 1970 440 block and ran into a problem with the thrust bearing. It looks to me that the side edges of the bearing are too large and the bearing will not seat properly. the machined groves in the block and the cap are smaller than the the surface of the bearing.
I crank doesn't drop into the bearing at all.
The bearings are standard size sealed power from a summit kit.
any help would be welcome,.
Ron
Re: 440 Thrust bearing problem [Re: Hem1orange] #1943998
11/02/15 11:06 PM
11/02/15 11:06 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
sounds like you have the cast crank bearing with the wider flanges and need the forged crank bearing with narrower flanges.
Re: 440 Thrust bearing problem [Re: lewtot184] #1944001
11/02/15 11:09 PM
11/02/15 11:09 PM
Colorado
Colorado
That makes a lot of sense. I didn't know that there was a difference.
Ron
Re: 440 Thrust bearing problem [Re: Hem1orange] #1944049
11/02/15 11:49 PM
11/02/15 11:49 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
There are 2 different thrust bearing sizes, depending on the year of the block. http://www.440source.com/bearings.htm
The only Carbs I care about are under the hood!
Re: 440 Thrust bearing problem [Re: Azzkikrcuda] #1944087
11/03/15 12:24 AM
11/03/15 12:24 AM
Colorado
Colorado
Thanks for the info.
I'm learning one mistake at a time.
Ron
Re: 440 Thrust bearing problem [Re: Hem1orange] #1944410
11/03/15 03:03 PM
11/03/15 03:03 PM
dogdays Offline
dogdays  Offline
Yes, it has nothing to do with the crank and everything to do with how the block was machined, early or late. Smallblocks have the same issue.
As thrust bearings see more stressed than the other main bearings, could be that someone would want it. Put it in the "For Sale" section.
R.
