1960 dodge clutch pedal set up. #1943458
11/02/15 03:31 AM
11/02/15 03:31 AM
wisconsin united states
K
keith airgrabber Offline OP
Right in the Nutz!!!
K
A local junkyard has a 1960 phoenix with a clutch pedal set up. Wondering if it is the same as 62-5 b-body?
Re: 1960 dodge clutch pedal set up. [Re: keith airgrabber] #1943544
11/02/15 11:16 AM
11/02/15 11:16 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRC from my 60 they are different than later say 63 up for sure.Might work but its been 50 years since I did my 60 Dodge.I know the 65 sedan I parted had different pedals than 65s.I still have them and no idea what they were from.Rocky
Chrysler Firepower
Re: 1960 dodge clutch pedal set up. [Re: keith airgrabber] #1943554
11/02/15 11:32 AM
11/02/15 11:32 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I am not sure about a 1960, but I can tell you that 62-63 clutch pedals are different from 1964-65 clutch pedals.
Matt
Re: 1960 dodge clutch pedal set up. [Re: keith airgrabber] #1943607
11/02/15 01:08 PM
11/02/15 01:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Different as in doesn't work or different as in doesn't look the same?
Don't be the exception.
Re: 1960 dodge clutch pedal set up. [Re: keith airgrabber] #1943664
11/02/15 02:33 PM
11/02/15 02:33 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
From my understanding 64-65 B body pedals will work in a 62-63 application, but 62-63 pedals will not work in 64-65 applications.
There is a piece welded on the front of the basket with a 90 degree bend that points down on 62-63 pedals and it points up on 64-65 pedals.
I will post some pictures from brewers performance website to help explain the difference. The first picture will be 62-63 pedals the second will be the 64-65 pedals.
Matt
Re: 1960 dodge clutch pedal set up. [Re: keith airgrabber] #1943761
11/02/15 04:41 PM
11/02/15 04:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I think you'll find that the '60 Dodge setup is more like the later C-bodies.
Re: 1960 dodge clutch pedal set up. [Re: keith airgrabber] #1943820
11/02/15 06:02 PM
11/02/15 06:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I know for sure the pedals are a ton different.They were huge when I did my 60 Dodge.Its been years but IIRC there were other differences.The set I pulled from a 65 are laters and I think Ebody.I know for sure they werent B body and they worked but look different than my 65s.Rocky
Chrysler Firepower
Re: 1960 dodge clutch pedal set up. [Re: therocks] #1944050
11/02/15 11:50 PM
11/02/15 11:50 PM
K
K
so they will not work in a 64 dodge. Thanks for the detailed info. I appreciate it.
