Re: 4 speed question
[Re: GKMOPAR]
#1942162
10/31/15 01:41 PM
10/31/15 01:41 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Have not touched it yet since I got it. Not sure of the brand on the clutch. The heavy spring on the pedal is in place. That spring needs to be removed when a diaphragm pressure plate is used. Your next question should be: how do I get the over center spring off without blood being spilled? Answer: with the pedal pushed all the way to the floor, stuff washers (or nickels) between as many of the coils as you can. when you release the pedal it will be long enough to remove easily. However: When you do this and the grabby problem does not go away then the disc may be either contaminated, broken or just too aggressive for street use.
[Re: GKMOPAR]
#1942241
10/31/15 03:06 PM
10/31/15 03:06 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
Have a 68 340 4spd in a GTS. The clutch is new and was installed before I got the car. It is the diaphram design. The issue I am having is that it is all or nothing. When I let out the clutch nothing happens until I get the pedal about half way up and it engages all at once. Kind of makes it difficult to drive. The fork looks to be about 12" long. Don't know if it may be the pressure plate or if there is an incorrect component throwing the geometry off. Any idea where to start? Most Mopars need to have the clutch adjusted so it doesn't engage completely down low due to the lack of travel, all the OEM Mopar 4 speed cars I've raced and driven on the street needed the adjustment to start mid pedal travel to end up with the throwout bearing not touching the pressure plate fingers with the pedal all the way out My 1969 Dart GTS 383 4 speed car had a hydraulic clutch with a 143 tooth flywheel with a 11 inch borg and beck clutch in it with a scattershield in it. I decided to buy new replacement clutch linkage and the proper bellhousing and flywheel to put it back to stock so I could use the other parts in another build, I put a Centerforce clutch in it with the same pressure plate as yours, I need to remove the overcenter spring now also. I have to use my foot under the clutch pedel to get it to raise all the way up so the throw out bearing isn't ridng on the presure plate fingers going down the road
[Re: GKMOPAR]
#1942387
10/31/15 06:37 PM
10/31/15 06:37 PM
Posts: 5,895 ohio
ruderunner
ohio
Spring needed for 3 finger clutches, not for diaphragm type. This isn't GM stuff
Angry white pureblood male
[Re: GKMOPAR]
#1942627
11/01/15 12:38 AM
11/01/15 12:38 AM
Posts: 20,189 Park Forest, IL
slantzilla
Park Forest, IL
Make sure you get the proper T/O bearing for your pressure plate. Diaphragm and B&B take different length bearings.
[Re: GKMOPAR]
#1942673
11/01/15 01:54 AM
11/01/15 01:54 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
If you run a CF dual friction daiphram you will never go 3 finger again.I ran McCleod 3200 pound for years.Then went CF.Its been 15 years and no problems and still bites like new.Im one of the people tha hates change.I ran a dual point up to a few years ago thats how much I dont like change.But the CF was one of the best I made.Oh yeah 7K shifts and never any problems Rocky
Chrysler Firepower
[Re: Cab_Burge]
#1943027
11/01/15 03:07 PM
11/01/15 03:07 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Most Mopars need to have the clutch adjusted so it doesn't engage completely down low due to the lack of travel, all the OEM Mopar 4 speed cars I've raced and driven on the street needed the adjustment to start mid pedal travel to end up with the throwout bearing not touching the pressure plate fingers with the pedal all the way out My 1969 Dart GTS 383 4 speed car had a hydraulic clutch with a 143 tooth flywheel with a 11 inch borg and beck clutch in it with a scattershield in it. I decided to buy new replacement clutch linkage and the proper bellhousing and flywheel to put it back to stock so I could use the other parts in another build, I put a Centerforce clutch in it with the same pressure plate as yours, I need to remove the overcenter spring now also. I have to use my foot under the clutch pedel to get it to raise all the way up so the throw out bearing isn't ridng on the presure plate fingers going down the road Just use a large carb return spring from the dash frame to the pedal (Hardware store, around 3/4" diameter). I always take the over spring out, Mopar or Chevy. I also put a small carb return spring on the linkage from the fork to the bellcrank to stop mishaps while driving.
[image][/image]
[Re: GKMOPAR]
#1943190
11/01/15 08:22 PM
11/01/15 08:22 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I don't think the problem is in the pressure plate. The all in at once is in the material the disc is made of. It's probably a replacement disc such as Kevlar or Ceramic material type. If you have a daily driver just get a replacement organic disc with a Borg/Beck pressure plate and throw out bearing assembly from the local auto parts store. Going with the aftermarket sets like Centerforce, Zoom, etc. probably will get you another grabby clutch.
[Re: GKMOPAR]
#1943258
11/01/15 10:14 PM
11/01/15 10:14 PM
GomangoCuda
I think I am going to drop the transmission due to an antifreeze leak on the back of the block. That could be the cause of your grabby clutch.
[Re: therocks]
#1943425
11/02/15 01:34 AM
11/02/15 01:34 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If you run a CF dual friction daiphram you will never go 3 finger again.I ran McCleod 3200 pound for years.Then went CF.Its been 15 years and no problems and still bites like new.Im one of the people tha hates change.I ran a dual point up to a few years ago thats how much I dont like change.But the CF was one of the best I made.Oh yeah 7K shifts and never any problems Rocky I'm with you on the Centerforce. Had one that you could easily press with your hand, yet it would scratch rubber in 3 gears and tow a truck. I'm all about the resistance to change but explain why do you all want a clutch pedal that is so hard to push it bends Z linkages and bends firewalls. GKMopar, there may be a racing set up in there. If it has no hub springs and ceramic pucks. Those definately act like ON/OFF switches.
[Re: Magnum]
#1943767
11/02/15 04:49 PM
11/02/15 04:49 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
[quote=therocks]
GKMopar, there may be a racing set up in there. If it has no hub springs and ceramic pucks. Those definately act like ON/OFF switches. This is what I was thinking.. This type of disc was in a car purchased by a friend in "the day".. Race application...
