How low can I take it? #1933701
10/17/15 10:55 AM
10/17/15 10:55 AM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Have a 76 D-100 I already lowered 2" up front, is there any way to go lower with out having any alignment issues? Any one ever move the upper control arms?
Re: How low can I take it? [Re: 68dodge] #1933727
10/17/15 11:50 AM
10/17/15 11:50 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I've herd of using van control arms to lower pu's but not sure what's involved.
Have a great day
Iowan
"obsolete is neat"
Re: How low can I take it? [Re: Iowan] #1933729
10/17/15 11:54 AM
10/17/15 11:54 AM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
3
I know about the lower control arm swap, but I want to go lower than a 2" drop.
Re: How low can I take it? [Re: 68dodge] #1933879
10/17/15 07:11 PM
10/17/15 07:11 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I got 3' out of mine
Dakota dropped spindles work too
Re: How low can I take it? [Re: 68dodge] #1938773
10/26/15 05:34 AM
10/26/15 05:34 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Van arms or cut coils along with Dakota Drop Spindles.
Re: How low can I take it? [Re: 68dodge] #1941376
10/29/15 11:40 PM
10/29/15 11:40 PM
MO
C_Notch Offline
C_Notch  Offline
MO
I used van lca, dakota drop spindles, and cut one full coil from springs. Front frame rail sits 9 1/4" off the ground. LCA and crossmember are a little over 2" off ground.
I run 255/55/17 up front and 285/70/17 rear
Re: How low can I take it? [Re: C_Notch] #1941625
10/30/15 12:50 PM
10/30/15 12:50 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Got any pics? Thats the tire size Im considering
Re: How low can I take it? [Re: 68dodge] #1941778
10/30/15 07:52 PM
10/30/15 07:52 PM
MO
C_Notch Offline
C_Notch  Offline
MO
far away.
