sudden loss of oil pressure #1941290
10/29/15 09:37 PM
10/29/15 09:37 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
something weird going on with my van that i love to drive constantly
I didn't get to drive my van the week I was at drag week then for maybe 2 weeks after due to floods and whatever. then a week ago I drove over to the next town about 13 miles, drive home and notice I don't have any oil pressure.
change oil and filter. change oil pressure sender. with a 1/2 drill 0-800 rpm with a mechanical gauge, it says 50 psi at full blast but if I run the drill slow half speed its at 25, slower and its like at 0. so I'm wondering at what rpm the oil pump spins relative to engine rpm. not sure if the gauge in the dash took a crap or if there is a problem. couple days ago, the mechanical gauge was reading near 0 when it was just idling but would go up to 25 when I revved it up. totally stumped
Re: sudden loss of oil pressure [Re: sixpackgut] #1941312
10/29/15 10:25 PM
10/29/15 10:25 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
did you notice any weird noises?i don't think it would take long to start rattlin with no op.
Re: sudden loss of oil pressure [Re: sixpackgut] #1941316
10/29/15 10:27 PM
10/29/15 10:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
oil pumps are cam driven so they should be half the crank rpm.
Re: sudden loss of oil pressure [Re: sixpackgut] #1941323
10/29/15 10:36 PM
10/29/15 10:36 PM
Charleston
Charleston
I just started it back up and its the same way. Very low oil pressure at idle. Hard to read exactly how low on mech gauge. Goes up to 50 if you rev it though. Lifters were ticking on startup
Re: sudden loss of oil pressure [Re: sixpackgut] #1941331
10/29/15 10:46 PM
10/29/15 10:46 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
small block?
Re: sudden loss of oil pressure [Re: sixpackgut] #1941342
10/29/15 11:01 PM
10/29/15 11:01 PM
Charleston
Charleston
Yes small block. I just dropped the pan on my ramcharger but i dont think i can get the engine high enough in the van to pull the pan.
At the point of cutting pan and welding it back together or pulling the whole van apart and dropping in a reman engine and having trans rebuilt
Re: sudden loss of oil pressure [Re: sixpackgut] #1941385
10/29/15 11:53 PM
10/29/15 11:53 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
what weigth oil did you use
try 20/50 see if presure gos up
1.39 9.85 - 137 mph
Re: sudden loss of oil pressure [Re: sixpackgut] #1941555
10/30/15 10:13 AM
10/30/15 10:13 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
my thoughts were to get the intermediate shaft out for inspection as a starter. there's a plug behind the shaft that if it's missing or fell out will definitely screw the oil pressure up.
Re: sudden loss of oil pressure [Re: sixpackgut] #1941557
10/30/15 10:20 AM
10/30/15 10:20 AM
, PA
sleepyhead416 Offline
, PA
A lot of miles ? valve seals stuck in oil pickup...
Re: sudden loss of oil pressure [Re: sleepyhead416] #1941568
10/30/15 10:36 AM
10/30/15 10:36 AM
an8sec70cuda Offline
iagree Did the small blocks come w/ the nylon lined timing gears like the big blocks did? That crap will get on the pickups also.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: sudden loss of oil pressure [Re: sixpackgut] #1941589
10/30/15 11:30 AM
10/30/15 11:30 AM
Charleston
Charleston
Its not the pickup getting clogged, that is the reason I just pulled the pan on my ramcharger. This is just different.
I just put 10-30 in it but was thinking I usually run 15-40 rotella in everything and thought maybe give it a try but I feel it just a waste of oil at this point
Re: sudden loss of oil pressure [Re: lewtot184] #1941590
10/30/15 11:32 AM
10/30/15 11:32 AM
Charleston
Charleston
I had it out and was looking in the valley while I was running the priming shaft and didn't notice anything other then drainback
Re: sudden loss of oil pressure [Re: sixpackgut] #1941598
10/30/15 11:45 AM
10/30/15 11:45 AM
I'd throw another gauge on it just to rule that out.
CHIP
Re: sudden loss of oil pressure [Re: sixpackgut] #1941633
10/30/15 01:27 PM
10/30/15 01:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
make sure the "drainback" isn't coming from the back of the driver side lifter galley.
Re: sudden loss of oil pressure [Re: sixpackgut] #1941636
10/30/15 01:40 PM
10/30/15 01:40 PM
Alberta
rustbuckett68 Online content
rustbuckett68  Online Content
Alberta
The pan on my 79 van came off with no issues, didn't have to lift the engine. Might have to rotate the crank to get the counter weights out of the way, but no big deal.
Re: sudden loss of oil pressure [Re: sixpackgut] #1941694
10/30/15 04:33 PM
10/30/15 04:33 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Make sure the pickup didn't Crack or fall off
Re: sudden loss of oil pressure [Re: FastmOp] #1941839
10/30/15 10:22 PM
10/30/15 10:22 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I saw this happen once on a small block oil pump. A piece of debris stuck the relief valve open.
Re: sudden loss of oil pressure [Re: sixpackgut] #1941845
10/30/15 10:33 PM
10/30/15 10:33 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
if the thicker oil picks up oil preasure then its time to rebuilt it
my 340 did this and with a new oilpump but at high rpms it would drop off
just save the oil for next time
1.39 9.85 - 137 mph
Re: sudden loss of oil pressure [Re: rustbuckett68] #1943170
11/01/15 07:50 PM
11/01/15 07:50 PM
Charleston
Charleston
79 must be different than a 77 because i dropped crossmember 3" and have engine jacked up 2" and i still cant get it off
Re: sudden loss of oil pressure [Re: sixpackgut] #1945016
11/04/15 02:37 PM
11/04/15 02:37 PM
Charleston
Charleston
pressure relief valve was stuck open. popped right back into place but I'm changing the pump.
