sudden loss of oil pressure
#1941290
10/29/15 09:37 PM
10/29/15 09:37 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
something weird going on with my van that i love to drive constantly
I didn't get to drive my van the week I was at drag week then for maybe 2 weeks after due to floods and whatever. then a week ago I drove over to the next town about 13 miles, drive home and notice I don't have any oil pressure.
change oil and filter. change oil pressure sender. with a 1/2 drill 0-800 rpm with a mechanical gauge, it says 50 psi at full blast but if I run the drill slow half speed its at 25, slower and its like at 0. so I'm wondering at what rpm the oil pump spins relative to engine rpm. not sure if the gauge in the dash took a crap or if there is a problem. couple days ago, the mechanical gauge was reading near 0 when it was just idling but would go up to 25 when I revved it up. totally stumped
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: sudden loss of oil pressure
[Re: sixpackgut]
#1941342
10/29/15 11:01 PM
10/29/15 11:01 PM
sixpackgut
Charleston
Yes small block. I just dropped the pan on my ramcharger but i dont think i can get the engine high enough in the van to pull the pan.
At the point of cutting pan and welding it back together or pulling the whole van apart and dropping in a reman engine and having trans rebuilt
[Re: sixpackgut]
#1941385
10/29/15 11:53 PM
10/29/15 11:53 PM
Posts: 5,618 long island NY
Ari440
long island NY
what weigth oil did you use
try 20/50 see if presure gos up
1.39 9.85 - 137 mph
[Re: sleepyhead416]
#1941568
10/30/15 10:36 AM
10/30/15 10:36 AM
Posts: 13,368 Marion, South Carolina [><]
an8sec70cuda
A lot of miles ? valve seals stuck in oil pickup... Did the small blocks come w/ the nylon lined timing gears like the big blocks did? That crap will get on the pickups also.
[Re: sixpackgut]
#1941589
10/30/15 11:30 AM
10/30/15 11:30 AM
sixpackgut
Charleston
Its not the pickup getting clogged, that is the reason I just pulled the pan on my ramcharger. This is just different.
I just put 10-30 in it but was thinking I usually run 15-40 rotella in everything and thought maybe give it a try but I feel it just a waste of oil at this point
[Re: lewtot184]
#1941590
10/30/15 11:32 AM
10/30/15 11:32 AM
sixpackgut
Charleston
my thoughts were to get the intermediate shaft out for inspection as a starter. there's a plug behind the shaft that if it's missing or fell out will definitely screw the oil pressure up. I had it out and was looking in the valley while I was running the priming shaft and didn't notice anything other then drainback
[Re: sixpackgut]
#1941598
10/30/15 11:45 AM
10/30/15 11:45 AM
an8sec70cuda
I'd throw another gauge on it just to rule that out.
[Re: sixpackgut]
#1941633
10/30/15 01:27 PM
10/30/15 01:27 PM
Posts: 3,916 usa
lewtot184
usa
my thoughts were to get the intermediate shaft out for inspection as a starter. there's a plug behind the shaft that if it's missing or fell out will definitely screw the oil pressure up. I had it out and was looking in the valley while I was running the priming shaft and didn't notice anything other then drainback make sure the "drainback" isn't coming from the back of the driver side lifter galley.
[Re: sixpackgut]
#1941845
10/30/15 10:33 PM
10/30/15 10:33 PM
Ari440
long island NY
I just put 10-30 in it but was thinking I usually run 15-40 rotella in everything and thought maybe give it a try but I feel it just a waste of oil at this point if the thicker oil picks up oil preasure then its time to rebuilt it my 340 did this and with a new oilpump but at high rpms it would drop off just save the oil for next time
1.39 9.85 - 137 mph
[Re: rustbuckett68]
#1943170
11/01/15 07:50 PM
11/01/15 07:50 PM
sixpackgut
Charleston
The pan on my 79 van came off with no issues, didn't have to lift the engine. Might have to rotate the crank to get the counter weights out of the way, but no big deal. 79 must be different than a 77 because i dropped crossmember 3" and have engine jacked up 2" and i still cant get it off
[Re: sixpackgut]
#1945016
11/04/15 02:37 PM
11/04/15 02:37 PM
sixpackgut
Charleston
pressure relief valve was stuck open. popped right back into place but I'm changing the pump.
