Re: 499 RB pump-gas cam suggestions 3.23 gears. [Re: SomeCarGuy] #1939857
10/27/15 08:42 PM
10/27/15 08:42 PM
IN
ahy Offline
ahy  Offline
IN
The "new" 528 has 112 LSA for better manners I guess. I believe the "old " 528 was tighter - something like 108 degrees.
Mike at Muscle Motors spec'ed my cam. It is a fast rate MM lobe, 243 duration, .55" lift, 108 LSA. Timing very similar to the "old" 528 just a bit more lift. 13" vacuum. I consider it choppy but I guess that is subjective. If you want it choppy, better to go the custom cam route with tighter LSA. Also, based on Mike's experience, 108 LSA is best for acceleration with this type of combo. I just know it works well... loads of mid range torque and will hang in to and beyond 6000 RPM if needed... eg. to get that last little bit of straight away before the turn without pulling 5'th gear.
Re: 499 RB pump-gas cam suggestions 3.23 gears. [Re: ahy] #1939950
10/27/15 10:28 PM
10/27/15 10:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Actually it's the MP509 that had the LSA widened from 108.
The 528 was always wide. 114?
Just looked it up. 112
Kevin
Re: 499 RB pump-gas cam suggestions 3.23 gears. [Re: SomeCarGuy] #1939956
10/27/15 10:40 PM
10/27/15 10:40 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Originally Posted By SomeCarGuy
Man just call Dwayne
x2.
The fastest way to being disappointed driving the car is buying a cam for the sound.
Re: 499 RB pump-gas cam suggestions 3.23 gears. [Re: moper] #1940104
10/28/15 02:45 AM
10/28/15 02:45 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
x2.
X3 I agree as I have a custom grind from Dwayne and it works just as I asked for. up Ron
Re: 499 RB pump-gas cam suggestions 3.23 gears. [Re: Twostick] #1940619
10/28/15 08:21 PM
10/28/15 08:21 PM
IN
ahy Offline
ahy  Offline
IN
Kevin
Thanks for the correction... agree as many have said, the the 528 with 112 may not be ideal for the OP's goals and a custom cam would be worth it.
Re: 499 RB pump-gas cam suggestions 3.23 gears. [Re: Bighead440] #1941553
10/30/15 09:56 AM
10/30/15 09:56 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Street driven just under 5,000 miles with:
Weekly Bracket race as well.
505 BBM
Pump Gas
Power Brakes
Comp Cam custom flat tappet by Nick @ Compuflo
1.5 rocker
.585 I, .600 E
260@50 I , 268@50 E
109 CL, 104 installed
3.23 gears, 9-1/2 Dynamic
With the 3.23 it bested 11.57, and couple of 11.59's, otherwise in the heat was an 11.60's car...at a hair over 116 MPH.
Father has same Comp Cam lobe family flat tappet in his 440 pump gas Roadrunner. He's got 3.23 as well.
He's bested 11.85 @ 112
otherwise it does 11.90's to 12.00's
If he'd drive it more that would be dandy. It idles like a pussycat.
Mike
Re: 499 RB pump-gas cam suggestions 3.23 gears. [Re: SILVER67] #1942546
10/31/15 10:22 PM
10/31/15 10:22 PM
Milledgeville, (central) Georg...
Bighead440 Offline OP
505 BBM
Pump Gas
Power Brakes
1.5 rocker
.585 I, .600 E
260@50 I , 268@50 E
Mike
NICE! RIP: Nick Wilson (CompuFlow). 260/268 @.050" flat tappet on a 109LSA makes me reconsider the 255 @.050" street roller on a 110LSA! I won't even have power brakes, I just wanted the vacuum as an indication of idle quality and throttle response. Thanks for the reply!!
