Re: Fuel Volume vs. Fuel Pressure
[Re: tboomer]
#1938138
10/25/15 02:22 AM
10/25/15 02:22 AM
Posts: 10,019 MN
JERICOGTX
MN
Ran -12 line from the cell to the Magnafuel500 pump, then -10 line to the regulator, then -8 line to the carb. Wiring to the pump is a often overlooked problem.
69 GTX
68 Road Runner
[Re: Jerry Kathe]
#1938209
10/25/15 11:06 AM
10/25/15 11:06 AM
Posts: 22,695 Bitopia
jcc
Bitopia
TBoomer - Monte Smith and Mark Whitener have answered this inquiry.....go back and re-read those posts. Been there, done that. (FWIW/IMO)
Like: "Bigger lines, hold more volume and the column of fuel is harder to move in a G situation, so you need more pump. Smaller lines help that...." Just don't tell your physics teacher.
[Re: Jerry Kathe]
#1938236
10/25/15 12:01 PM
10/25/15 12:01 PM
jcc
Bitopia
Its about volume, not pressure.
I don't invest much concern when comparing say a -10 line v/s a -8 line in column reaction to G-forces - but there is some relevance to the general concept and statement.
FWIW - in having a professional education and occupational discipline in the engineering field.....I understand hydraulic physics and dynamics, no need to consult the teacher. I have no idea what you are saying, other then your stated qualifications. To be clear, explain what "relevance to the general concept and statement" means relating to this topic. I would like to hear someone explain how tubing size diameter effects PSI, under g forces. I tried, but everybody? got lost in the weeds, to use another analogy.
[Re: Monte_Smith]
#1938330
10/25/15 02:44 PM
10/25/15 02:44 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
As I read through all of this I am reminded of the mistakes/leasons I have learned about pump placement size/style of the pump, running voltage to the pump, tank placement and g-force. But I am just a dumb electrician, not a rocket doctor.
Some need to remember there is a big difference between a tank at the rear of the car way behind the regulator and carb and a tank ahead of the pump and the rest of the system.
The fuel aeration/pressure discussion is interesting, and I have to think about how some push vacuum referenced regulators and the effect that would have in the fuel bowl.
Thanks for a discussion that is useful
"Just a Bracket car dressed up like a streetcar"
[Re: tboomer]
#1938341
10/25/15 03:11 PM
10/25/15 03:11 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
For a vast over simplification of pressure vs volume.........lets relate it to electricity. A 20 gauge speaker wire will carry 12 volts(pressure) and so will a 00 welding cable, but only one of those will crank your car, because only one carries enough volume(amps) of electricity to operate the starter motor. I can crank the pressure(voltage) up on the small wire to 16 volts and it still won't crank the car.
So your motor requires a volume of fuel to run properly. If the pump and line can't supply that volume, no realistic amount of pressure increase is going to overcome the lack of volume.
As for the lower pressure, decreasing aeration of the fuel and the car running better...........that has been proven time and time again on the RACETRACK........NOT on a piece of paper
[Re: Monte_Smith]
#1938346
10/25/15 03:31 PM
10/25/15 03:31 PM
jcc
Bitopia
Give it up Jerry...........you can't have a legitimate race car discussion with some here. Now if you want to talk about water cisterns, gravity on Saturn and golf balls, you are in the right place. When you label other peoples comments "crap", I would agree about the comment of having legit discussions here, about anything.
[Re: tboomer]
#1938354
10/25/15 03:54 PM
10/25/15 03:54 PM
Posts: 1,532 off the grid
340B5
off the grid
Considering the conversation has turned to aeration a couple times;
I have a deep (11") fuel cell and have never had a down tube on the return inside. I've always reasoned that the bubbles will float to the top before they get pulled into the inlets. Would it benefit me to use a downtube?
I was planning on finally putting one on this winter.
Yeah, it's got a smallblock.
[Re: jcc]
#1938365
10/25/15 04:13 PM
10/25/15 04:13 PM
Monte_Smith
North Alabama
Give it up Jerry...........you can't have a legitimate race car discussion with some here. Now if you want to talk about water cisterns, gravity on Saturn and golf balls, you are in the right place. When you label other peoples comments "crap", I would agree about the comment of having legit discussions here, about anything. Here is the thing.........you don't agree with me, that's fine, because I really don't care if you do. I base my suggestions here from things I have tried and KNOW they work, not based from some formula that SHOULD work or is written in a book. So yeah, when you start talking about water cisterns on Saturn and the differences in gravity to prove your point, which is totally irrelevant to the discussion at hand, I zone out and consider that info useless. Nobody care about that stuff. They want to know what will WORK on their race car. If you and a couple others, think you are the ONLY ones on here with an engineering background, you are sorely mistaken. And if there is one thing I have learned working with other engineers, is that because they can figure things out on paper, doesn't mean they can make anything WORK. Going through that right now, with a self proclaimed "genius" engineer we hired. Nothing he has done for us has worked. So what does that mean........it means a piece of paper is a piece of paper
[Re: 340B5]
#1938392
10/25/15 05:07 PM
10/25/15 05:07 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I was planning on finally putting one on this winter. When my Magnafuel 300 pump died on me the tech at Mag said it had been cavitating and asked about the down tube which I did not use till AFTER I got the pump back. He also said running the cell low and hard braking can uncover the sump and also kill it. He also mentioned foam which I run can also crowd the outlet fittings ALSO causing a restriction. So I now run the down tube, keep the cell at least 1/2 full and will address the foam issue somehow.......
[Re: tboomer]
#1938425
10/25/15 06:19 PM
10/25/15 06:19 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
So, since I started racing, (back when electricity was first invented, I think) I used 2 Holley blue pumps with Moroso springs, 2 1/2" fuel lines, into 2 Holley regulators tee'd together and into the fuel bowls. I think the Moroso spring and shim kits set the line pressure around 28 psi, and then adjusted the regulators to 5 psi each, which would be 5.5 when both pumps were running. Would lowering the regulator pressure be beneficial as far as aeration or is this a satisfactory setup? Still unsure of a new setup for the new combo. Was thinking leaving the pumps, feed the supply lines into a Y block in front of a single four port regulator. Oh, and the lines off of the fuel cell are -10. The biggest addition to my new combo will be adding an alternator this year.
[image][/image]
[Re: tboomer]
#1938496
10/25/15 08:18 PM
10/25/15 08:18 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I'm not a smart man. But you know who I'm going to listen to in a discussion like this? Guys with real hands on knowledge of making a car go down a track fast. Guys like Monte, and Thumper. Because they have tried "theories" "formulas" "calculations", And what ever else a book says will work. And what usually happens? They don't work. What works on paper, or even a dyno, might not happen going down the track.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#1938521
10/25/15 08:55 PM
10/25/15 08:55 PM
Posts: 25,885 United Socialist States of Ame...
tboomer
I'm not a smart man. But you know who I'm going to listen to in a discussion like this? Guys with real hands on knowledge of making a car go down a track fast. Guys like Monte, and Thumper. Because they have tried "theories" "formulas" "calculations", And what ever else a book says will work. And what usually happens? They don't work. What works on paper, or even a dyno, might not happen going down the track. This!!!!! ^^^^^^^^^^^^^^^^ I could care less about theory. I just want something that works and there has been a lot of good advice here given by people who have been there and done that!
