Page 2 of 3 1 2 3
Re: Alternator upgrade? [Re: Wedgeman] #1937946
10/24/15 09:03 PM
10/24/15 09:03 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Originally Posted By Wedgeman
Does the Denso have a built in regulator ?
Yes
64 Plymouth Savoy
Dana 60
Re: Alternator upgrade? [Re: justinp61] #1937947
10/24/15 09:06 PM
10/24/15 09:06 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
COOL
where to find a wiring diagram for this ?
Any part number someone ?
Dan
Re: Alternator upgrade? [Re: 451Mopar] #1937948
10/24/15 09:08 PM
10/24/15 09:08 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Originally Posted By 451Mopar
Anyone use one of these? I got the web link from the JOC (Jensen Owners Club)
http://www.qualitypowerauto.com/item_557/Chrysler-Mount-Mega-Amp-Alternator.htm
I ran one of their older Ford case converted 140 Amp models. It was what I needed for 2 fans and H4 headlights. Put out 95A at idle.
Mopar to the bone!!!
Re: Alternator upgrade? [Re: justinp61] #1937951
10/24/15 09:11 PM
10/24/15 09:11 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Must be something in my router, it works on my phone on 4g.
http://arengineering.com/wordpress/wp-content/uploads/ARE-AR022-proof.pdf
Re: Alternator upgrade? [Re: Wedgeman] #1937953
10/24/15 09:15 PM
10/24/15 09:15 PM
Rittman Ohio
Rittman Ohio
COOL
Dan
I think Andy can hook you up with a connector and how it's hooked up. I got the connector when I salvaged the alternator off a Toyota pickup.
Andy will hook you up with all the brackets and I think he even makes a trick pulley for it too. Just check the AR Engineering website for everything you need for the conversion.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Alternator upgrade? [Re: fourgearsavoy] #1937993
10/24/15 10:42 PM
10/24/15 10:42 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
If 120 amps is all you need, then look for a Denso alternator from a '89-'91 Dodge Ramcharger. I bought one from this company, works great. It's new, and its reasonably priced. It works with the standard Mopar external regulator.
120 amp Denso alternator
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Alternator upgrade? [Re: justinp61] #1938030
10/24/15 11:20 PM
10/24/15 11:20 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I use the 14611 Denso off ebay, it was cheap and shows 14 volts in my car at all times, best charging setup I've ever owned. AR-Engineering sells the wire pigtail, motor plate mount, and pulley for it.
I don't have a good photo of mine but this is Butch's photo...
Re: Alternator upgrade? [Re: justinp61] #1938031
10/24/15 11:21 PM
10/24/15 11:21 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Mounting kit
Re: Alternator upgrade? [Re: justinp61] #1938032
10/24/15 11:23 PM
10/24/15 11:23 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Harness
Re: Alternator upgrade? [Re: DusterDave] #1938116
10/25/15 01:36 AM
10/25/15 01:36 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Do you have to use a regulator ? I thought you just ran a single wire back to the battery ? Gary
Re: Alternator upgrade? [Re: Gabby63] #1938262
10/25/15 12:50 PM
10/25/15 12:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The Denso is internally regulated and one goes to 12+ and one to keyed 12+ iirc.........
Re: Alternator upgrade? [Re: justinp61] #1938263
10/25/15 12:51 PM
10/25/15 12:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I don't use a regulator with the 14611, it's internally regulated as far as I know. It's only 60 or 70 amps but it sure does the job.
Re: Alternator upgrade? [Re: justinp61] #1938273
10/25/15 01:06 PM
10/25/15 01:06 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
On the 3-wire harness:
Red is not used.
Blue goes to the large post on my starter relay(always hot).
Green goes to a switched 12 volt fuse.
Re: Alternator upgrade? [Re: ProSport] #1938292
10/25/15 01:44 PM
10/25/15 01:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya, I didn`t have the connector so I ran one to constant 12+ and the other to a switched 12+ and as you said, the third wasn`t needed.......
Re: Alternator upgrade? [Re: justinp61] #1938301
10/25/15 02:03 PM
10/25/15 02:03 PM
W. Kentucky
W. Kentucky
There is a diagram in the link I posted to Andy's site.
Re: Alternator upgrade? [Re: justinp61] #1938311
10/25/15 02:16 PM
10/25/15 02:16 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
East coast makes the mini alternator in 1 wire and with the pullys you need.
Re: Alternator upgrade? [Re: FastmOp] #1938323
10/25/15 02:30 PM
10/25/15 02:30 PM
W. Kentucky
W. Kentucky
Will it work with the brackets I already have?
Re: Alternator upgrade? [Re: justinp61] #1938951
10/26/15 03:06 PM
10/26/15 03:06 PM
W. Kentucky
W. Kentucky
Thanks for all the info guys. up
Re: Alternator upgrade? [Re: 451Mopar] #1938981
10/26/15 03:41 PM
10/26/15 03:41 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Be interesting to hear feedback. They offer a high output 4 Runner alternator. I messaged them to see if it is a direct replacement for the Denso 210-0106 used in Any's kits. I want to go electric fan/water pump/EFI and want a bit more juice than the off the shelf Denso.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Alternator upgrade? [Re: justinp61] #1939086
10/26/15 06:49 PM
10/26/15 06:49 PM
Don't forget to make SURE your factory wiring and amp gauge will handle the increased amps SAFELY scope We don't need to read a post from you or anyone else on here about having a wiring meltdown or burnt up car from melted wires catching on fires shruggy
Page 2 of 3 1 2 3
