F150 MPG changes 2wd vs 4 wd or higher weight #1935451
10/20/15 10:41 AM
10/20/15 10:41 AM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
http://wot.motortrend.com/2016_ford_f_15...tors_picks=true
the V8 Pickup fuel economy drops are probably similar on Rams
Re: F150 MPG changes 2wd vs 4 wd or higher weight [Re: 360view] #1935460
10/20/15 10:54 AM
10/20/15 10:54 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
i guess you could cross check these numbers to roughly calculate how much the 400 to 500 weight savings from aluminum body panels give in fuel economy changes in the non real world EPA test proceedure
