Page 3 of 3 1 2 3
Re: Boneyard Front Suspension [Re: Greg55_99] #193460
02/03/09 10:13 AM
02/03/09 10:13 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
What about looking into the 98-2001? Crown vic. I know that in 2002 they used a different setup for the arms and all. Shocks are a different part due to the redesign. They also had a deeper offset rim as well. Still needed 16" rims though.
From what I can see, some of them had a stamped steel lower A arm and others had a cast aluminum one. Maybe that's what the difference is. Problem is, it looks like the attachment points are still the same between them.
Greg
Reading through the post it was mentioned that previous to '02 the front suspension doesn't detach from the frame rails.
Re: Boneyard Front Suspension [Re: MarkZ] #193461
02/03/09 03:07 PM
02/03/09 03:07 PM
canada
jneuf Offline
jneuf  Offline
canada
for interesting reading...
Re: Boneyard Front Suspension [Re: jneuf] #193462
02/03/09 06:03 PM
02/03/09 06:03 PM
MA
Greg55_99 Offline OP
MA
From what I'm reading now, it looks like the Police Cars and the Marauder's got the alloy lower A arms. The others got stamped steel. Dragaddict sent me this pic from his Merc.
Sure wish I could make this one fit....
Greg
Re: Boneyard Front Suspension [Re: None2Slow] #193463
02/03/09 10:33 PM
02/03/09 10:33 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
older ones have a weld-in front cross member, not a bolt in. they are 2-4" narrower, though, still a bit wide for an F/M/J and earlier B unless you go with late model mustang offset rims
2017 Grand Cherokee Overland
Re: Boneyard Front Suspension [Re: patrick] #193464
02/03/09 10:59 PM
02/03/09 10:59 PM
MA
MA
Anybody know how wide the Dakota track is? Industrial Chassis in Phoenix makes a kit to use Dakota parts for a front end swap. Looks good. Might be a better fit than the Ford. About $700 for the crossmember.
http://www.industrialchassisinc.com/
Greg
Re: Boneyard Front Suspension [Re: Greg55_99] #193465
02/03/09 11:07 PM
02/03/09 11:07 PM
Land of Lost
flatlinedude Offline
No pulse
No pulse
Land of Lost
Greg
Looks like the dakota will get you closer...
https://board.moparts.org/ubbthreads/show...rue#Post4983593
Carol: "Wow! He's really fast, isn't he?!" John: "Yeah... but he's stupid."
Re: Boneyard Front Suspension [Re: flatlinedude] #193466
02/03/09 11:58 PM
02/03/09 11:58 PM
MA
MA
Greg
57" outside to outside for the Dakota? Close...
Greg
Re: Boneyard Front Suspension [Re: Greg55_99] #193467
02/04/09 10:18 AM
02/04/09 10:18 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I have been wondering if a guy could take a Vic front end, fit a narrower steering rack, and just section the crossmember to the correct width.
I suppose the trick would be finding a rack with the same mounting bolt mounting positions relative to each end of the rack.
My Ranger is screaming at me to try this. lol
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Boneyard Front Suspension [Re: BBR] #193468
02/04/09 09:29 PM
02/04/09 09:29 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Sectioning the rack would sure seem like an option to me. There must be some options for different racks - Mustang? Mustang II? maybe even different OTRE's that could make up the difference.
Clair
Re: Boneyard Front Suspension [Re: Clair_Davis] #193469
02/04/09 10:02 PM
02/04/09 10:02 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
The Crown Vic cross member is aluminum, so not something that would normally be narrowed at home.
For me, the big plus of this piece, is that it is a bolt on, and won't pose any questions of weld strength and quality later on.
Re: Boneyard Front Suspension [Re: dave571] #193470
01/02/14 07:38 PM
01/02/14 07:38 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I realize this thread is old but i saw this from the OP on the grassroots motorsports forum and wonder if it went anywhere...
Well, I've actually come across another option that I like better. Something came up on my radar screen that REALLY got my attention. That is, the drop out IFS from a 93-04 Lexus SC300400. It's a REAL nice looking piece and it's got a hair over 34" between the frame rails. Just like the F-body. It can use HUGE Turbo Supra brakes and it bolts to the frame. F body front track width is listed as 60.0"
Re: Boneyard Front Suspension [Re: Pool Fixer] #193471
01/03/14 12:21 PM
01/03/14 12:21 PM
MA
MA
Good grief. It has been a long time since I posted this. At the time I was looking for an inexpensive method of getting rid of the torsion bar set up in my Volare. I did a lot of searching and finally found an old version crossmember from Industrial Chassis in Phoenix to mount the Dakota parts. I've done some cutting and I'm in the process of getting it installed.
I honestly believe the Lexus IFS would be a good, pure junkyard alternative. Track width and distance between the frame rails is good for an A, B, or E body. But if you look at the assembly, you'd have to figure out a way to mount coilovers between the upper and lower A arms. Not a deal killer.
Greg
Re: Boneyard Front Suspension [Re: Greg55_99] #193472
01/04/14 01:19 PM
01/04/14 01:19 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Another option that might have been a good fit would be a Pacer IFS. I was going to put one in my Scout but the frame rails were slightly over 35 inches outside to outside so it would have required frame or crossmember modification.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Boneyard Front Suspension [Re: Greg55_99] #193473
01/05/14 02:42 PM
01/05/14 02:42 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Life has kind of gotten in the way of my car hobby for a while, but it's great to be reminded how much great tech is right here on Moparts, and that I was even thinking about "back in the day"...
Clair
Page 3 of 3 1 2 3
