Boneyard Front Suspension
#193420
01/14/09 04:16 PM
01/14/09 04:16 PM
Posts: 300 MA
Greg55_99
MA
OK, so I hope I don't piss off the purists, but, I'm looking seriously into a couple of IFS packages straight from the boneyard. I've seen the Alterkation and XV setups and WOW, they are excellent! But, I'm an old hot rodder... so... Recently, on another board, a gent posted some pics of the front cradle from a 03-09 Ford Crown Victoria. He's putting it into an old pickup. I have a 77 F body Road Runner. The track width of the Crown Vic and F body are pretty close. The good part is, the Crown Vic front suspension completely unbolts from the car. Complete, hub to hub with power steering rack and a-arms. The Police car versions are the best. Since hot rod truck guys have been puting Volare front suspensions into old trucks, why not the Ford? I'm also playing with the idea of fitting a T-Bird independent rear suspension as well. More here: http://www.ford-trucks.com/forums/716058-buildup-06-crown-vic-front-suspension-into-67-f100.htmlLike I said... If it can be done in a truck... why not a car? Greg
Re: Boneyard Front Suspension
[Re: Greg55_99]
#193422
01/14/09 04:39 PM
01/14/09 04:39 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
they are similar track width as an F body? my friend's grand marquis feels a good 4-6" wider than my 5th ave...
[Re: patrick]
#193424
01/14/09 10:14 PM
01/14/09 10:14 PM
Posts: 2,826 NY usa
540challenger
NY usa
Maybe he is refering to the framerails not the body ????
[Re: Greg55_99]
#193428
01/15/09 02:02 AM
01/15/09 02:02 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
OK, so I hope I don't piss off the purists, but...
Man! Am I pissed!!!
Just kidding. Hey if it works and it don't hurt anybody, why not Sounds like a fun project! I had a 56 D100(?) (1/2 ton pu) I wanted to put a modern front end under. That would have been perfect!
[Re: Greg55_99]
#193430
01/15/09 04:21 AM
01/15/09 04:21 AM
Posts: 10,124 A Red State
SNK-EYZ
A Red State
Cool idea! Hopefully it will work for you. It sounds like you're going to need some positive offset wheels (offset to under the car) to make it work though. I guess it just depends on what wheels you were planning on using.
[Re: patrick]
#193433
01/15/09 07:56 PM
01/15/09 07:56 PM
Posts: 16,808 Between Houston & Galveston TX
SattyNoCar
sounds like it'd be an interesting setup for a late B ('71-up) or a C body. Wonder how hard it would be to mount in a unibody car? Since '73-up B's are the red headed step childs of Mopar and NO ONE will build a custom front end for them, this seems like an interesting alternative. Could this be the Mustang II front end of the new milenium?
John
[Re: SNK-EYZ]
#193434
01/16/09 02:00 PM
01/16/09 02:00 PM
Posts: 300 MA
Greg55_99
MA
I've been told that Magnum and Charger wheels work perfectly and have the correct backspacing.
Greg
[Re: B5TA]
#193436
01/17/09 06:25 PM
01/17/09 06:25 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Keep in mind for any car you install this in: The orientation this was mounted in the 'Vic is part of the caster 'equation', so that must be taken into account when mounting it into the new car. If you simply mount it 'flat' into the new car there might not be suitable range of caster adjustment. The 'Vic framerail angle with respect to the horizon should be compared to the angle on the receiver car. Does this mean we'll see an influx of 4.6 engines installed in Mopars???
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: B5TA]
#193437
01/17/09 07:19 PM
01/17/09 07:19 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
Hi, After reading your post I got sorta excited, I have a '62 Merc. Comet that I went out and measured but it looks like the Crown Vic. front end is to wide . So is there anything out there that is made that way only not as wide of track? Thanks , Kev
Anything for an early mustang should work under the comet, when my Dad had a '62 comet he used a disc brake setup from a 65-66 mustang, is yours a 6cyl or V8 car? his started came with a 221 so it was already 5 lug.
[Re: Clair_Davis]
#193438
01/18/09 12:09 AM
01/18/09 12:09 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
FWIW, I know of a guy who has a T-bird rear under a 66? Dart...
As luck would have it, he (David Belau) posted some links to some articles he posted on Cardomain just the other day: Article 1 Article 2
Great looking project he's got going there.
Clair
