Re: Trick Flow heads
[Re: B Dartman]
#1938059
10/24/15 10:49 PM
10/24/15 10:49 PM
Posts: 3,171 Wichita Kansas
B Dartman
Wichita Kansas
Even more interesting is the fact that the rocker shaft studs need to be all short ones. No long ones required. I used 10x of the 2.500 ARP stud and it worked just fine. For assurances, what is the ARP Part#?
[Re: B Dartman]
#1938264
10/25/15 11:52 AM
10/25/15 11:52 AM
Posts: 1,818 North Dakota
Azzkikrcuda
North Dakota
Longer head bolts if you already have a stock length 145-3606 ARP Hex head bolt kit and just want to buy the ten longer bolts instead of a complete 145-3609 kit are ARP-HAP4500-5
The only Carbs I care about are under the hood!
[Re: Beep Beep]
#1938454
10/25/15 06:27 PM
10/25/15 06:27 PM
Posts: 31,274 Oregon
AndyF
AndyF,
What is the part number for those rocker cover gaskets. Are those from Felpro? Moroso makes them. Rubber coated steel. They work really well with a cast valve cover that has a flat rail. About the only gasket that works with a vacuum pump. http://www.summitracing.com/parts/mor-93055/overview/
[Re: fast68plymouth]
#1938509
10/25/15 07:32 PM
10/25/15 07:32 PM
Posts: 17,929 Akron, Ohio
ProSport
Akron, Ohio
I've had no luck with those Moroso gaskets, probably cuz I over-torque them. The Superformance gaskets are 10 times better in my opinion.
[Re: ProSport]
#1938527
10/25/15 08:01 PM
10/25/15 08:01 PM
Azzkikrcuda
North Dakota
ARP part number for the 2.75 long studs should be ARP-AJ2-750-1B
