NEW Predator tool steel shaft rocker
#1932637
10/15/15 03:01 PM
10/15/15 03:01 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
These New CAm FX shaft rockers are tool steel, are lighter on the valve tip than a aluminum rocker, less deflection , needle or bushed tips,don't have the short cycle life that aluminum has.,and all parts are made right here in America. All ratios are available. Rockers are complete with tool steel shafts,tips and ajusters...pm me for details...LIFETIME WARRANTY!!! Tony
Re: NEW Predator tool steel shaft rocker
[Re: boatracer572]
#1932646
10/15/15 03:14 PM
10/15/15 03:14 PM
Posts: 20,156 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That looks very VERY nice!!!!!!!!!!
[Re: boatracer572]
#1932698
10/15/15 05:03 PM
10/15/15 05:03 PM
Posts: 19,359 Las Vegas
Al_Alguire
Las Vegas
Seriously they look nice. What ratios are available??
[Re: Al_Alguire]
#1932716
10/15/15 05:50 PM
10/15/15 05:50 PM
boatracer572
San Jose Ca.
was told anything up to 2.1, these are similar but not big chief rockers....
[Re: boatracer572]
#1932736
10/15/15 06:21 PM
10/15/15 06:21 PM
Posts: 4,206 New York
polyspheric
New York
Right - if it looks good, the engineering must be perfect, since (as we all know) all bad designs have rough edges, tool marks, etc.
Boffin Emeritus
[Re: boatracer572]
#1932813
10/15/15 09:22 PM
10/15/15 09:22 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
These are individual shaft rockers. The smaller axle only spans the width of the rocker. There is a bolt on both sides. 16 bolts hold the rockershafts(splayed valve) instead of 5 on an inline arrangement. Totally different application. not an apples to apples comparison.
[Re: boatracer572]
#1932907
10/15/15 11:40 PM
10/15/15 11:40 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
I ordered a set of those weak, ill engineered, not as good as aluminum babies today so I guess it was all just one big mistake given the theory of how weak they are.
Having seen plenty of the guy's work, on plenty other tappets, and complete rocker system, and having seen stiffer exhaust rockers pick up power. I think it'll all be ok.
I only use steel on the exhaust side, and I've seen it make more power for anyone interested, or has high cylinder pressure IE blown, or heavy nitrous.
i can attest that EVERYTHING the guy makes is as nice as it comes. Most especially his tappets.
[Re: dthemi]
#1932987
10/16/15 01:22 AM
10/16/15 01:22 AM
boatracer572
San Jose Ca.
[Re: boatracer572]
#1933158
10/16/15 12:13 PM
10/16/15 12:13 PM
polyspheric
New York
Literacy evidently not a requirement...
Boffin Emeritus
[Re: boatracer572]
#1933255
10/16/15 03:11 PM
10/16/15 03:11 PM
Posts: 200 AB
Efidart
AB
I run the T & D stainless rockers on the intake and exhaust since its a forced induction app. Did the needle bearing tips and spring oiling option which has performed flawless so far.
Wonder if these are any cheaper than the T&D?
Then again the aluminum ones seem to stand up to boost with no problems with other guys.. Piece of mind costs big money it seems.
What does everyone run for lifters and pushrods?
Smith bros 1/2" to 7/16" taper here and Isky EndurX EZ Roll 3372-EZX I think is the PN.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: Efidart]
#1933261
10/16/15 03:25 PM
10/16/15 03:25 PM
Posts: 1,403 Chesterfield Twp. Mi.
John Burdine
Hey, Matt. I will be running the Jesel Sportsman .937 lifters, pushrod oiling.
[Re: Efidart]
#1933659
10/17/15 03:06 AM
10/17/15 03:06 AM
boatracer572
San Jose Ca.
1.062" cam FX keyway lifters- 9/16 .188 wall double taper pushrods
[Re: camastomcat]
#1933804
10/17/15 03:16 PM
10/17/15 03:16 PM
boatracer572
San Jose Ca.
I You guys are running some big stuff in the valve train. I'm just using aluminum rockers with 7/16 double taper pushrods and .937 Crower .180 offset tappets, and as Tony says "smallish cam for a Predator". How much compression are the N/A guys running and how much HP are you expecting to see? Also, what timing are you running? 16.44 to 1 tom as you know, think should be able to make 1270+ hp N/A .expecting total timing to be around 31 degrees , will find out in a month or two on S&S Dyno......
[Re: polyspheric]
#1933842
10/17/15 05:26 PM
10/17/15 05:26 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Right - if it looks good, the engineering must be perfect, since (as we all know) all bad designs have rough edges, tool marks, etc. Care to elaborate on anything.............or are you just content to make vague shots from the outfield
[Re: John Burdine]
#1933846
10/17/15 05:31 PM
10/17/15 05:31 PM
Monte_Smith
North Alabama
Why does the stiffer rocker on the exhaust side make such a difference? Exhaust side is critical and as stated opens against more pressure. Valvetrain deflection is an issue. Also, you do NOT want a failure on the exhaust side in any motor, but especially a boosted or nitrous motor. With a broken exhaust rocker, the intake keeps piling stuff in the cylinder, but it's not getting out. The NEXT thing to "get out" is usually a rod. As for Cam FX, I run their keyway lifters..............top notch stuff
[Re: EchoSixMike]
#1933932
10/17/15 09:23 PM
10/17/15 09:23 PM
boatracer572
San Jose Ca.
Anyone know if there's any plans to make these for B-1 heads? Or Jesel Tomahawk stuff? S/F.....Ken M I think Chris can make rockers for just about anything! he has 4 cnc machines. If there is a demand (a few sets ) Im sure he would make a run of them.
[Re: Twin Turbo Mower]
#1934479
10/18/15 08:52 PM
10/18/15 08:52 PM
boatracer572
San Jose Ca.
Does the predator heads require offset lifters? No, I do not run offset lifters in mine.....
[Re: boatracer572]
#1934663
10/19/15 02:48 AM
10/19/15 02:48 AM
Al_Alguire
Las Vegas
Mine are .937 Jesel keyways. We spread them out as well to get them as straight as we could with the block we had. Also using all left hand offsets. Mine are about a straight as they can get. Required a lot of clearancing to block and heads as well. Still not quite ready but inching closer. Now with the season for the heads up car done things should move a little faster.
[Re: boatracer572]
#1934888
10/19/15 01:13 PM
10/19/15 01:13 PM
Al_Alguire
Las Vegas
Well since everyone is singing his praises I guess someone has to be a little rain. I have found Chris EXTREMELY hard to get ahold of. Don't want to go into to much detail but our experience with them has not been very good. Maybe just bad luck on our part.
[Re: dthemi]
#1936946
10/22/15 08:28 PM
10/22/15 08:28 PM
boatracer572
San Jose Ca.
I just added to my order with CamFX. Aside from the tool steel rockers and 1 inch tappets, I'm having Chris make a full set of Ti rockers for my next predator build as well. I'll post up some pictures when I see them.
Having a better base plate will be nice as well. There's nothing at all wrong with the T+D, just like everything else in the world. There's always something better.
Chris made Ti rockers for some of the winning PS teams before ti rockers got outlawed for PS by the good ole NHRA.
Monte, if you're reading this could you weigh in on the super A nozzle from nos? My manifold has 2 bungs for 90 degree nozzles in each runner, and I don't really want to re fit to annular. The scoop comes down over the manifold as well, I think making annular even more difficult to fit (I think). I'm looking for the meanest 90 nozzle there is.
Yep, Chris told me about your rockers..... 👍👍👍👍👍
