flexplate for a pro torque six bolt torque converter #1930483
10/11/15 10:38 PM
10/11/15 10:38 PM
iowa
wesw Offline OP
wesw  Offline OP
iowa
I'm installing a Bruno drive with a lenco three speed in my car. I have a pro torque 6 bolt torque converter for it. Who's flex plate do I need to bolt it to Mopar 8 bolt crank? Three of the holes line up with my JW flex, the other three are out by the flexplate ring gear. thanks wes
598 ci predator
Re: flexplate for a pro torque six bolt torque converter [Re: wesw] #1930606
10/12/15 01:36 AM
10/12/15 01:36 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have an ATI
Re: flexplate for a pro torque six bolt torque converter [Re: wesw] #1931629
10/13/15 08:50 PM
10/13/15 08:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Call Reactor...
Re: flexplate for a pro torque six bolt torque converter [Re: Al_Alguire] #1931900
10/14/15 09:53 AM
10/14/15 09:53 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Not going to happen with 130 tooth Mopar wheel and standard 6 bolt GM patterns. You either need the outer three lugs moved to smaller pattern or if you bell is built to accept moving the starter out for 153 tooth option. Some custom bells for Bruno's have this.
