i traded for a 74 Duster and someone had put a 360 magnum engine in it. it has a vibration. I know nothing about Magnum engines put I do know the flywheel / flex plates are different from LA engines this car is an automatic, before I do anything I was wondering which should it have? the magnum style flywheel or the 727 style flex plate if its wrong could that be the problem?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
