Best glass on the market? #1925991
10/05/15 01:51 AM
10/05/15 01:51 AM
resq302
resq302
As some of you might know, I do some work on friends cars / parts for their Mopars. Recently a friend of mine asked me if I would be able to change out his windshield since he had a crack in it and knew I had done a couple of them with no issues. He couldn't find any place who would use the correct 3M bedding and glazing compound. All of the glass places up here want to use the urethane sealer which will ruin your rubber gasket and my experience has only had them leak.
Reluctantly I accepted the job (as installing glass seems to be some form of art!) and he ordered new tinted windshield from ECS to keep with the original markings on the glass which were there before. We also picked up a new gasket from Dante's to assist in making the installation a little easier since the old gasket was fairly hard. This was now my 4th windshield installation so as you can imagine, I was pretty nervous doing the job. I've had issues with other glass sealing or not being thick enough which left a gap in the rubber gasket. The best I had ever used (till that day) glass wise, was PPG. I was very impressed by the quality of the ECS windshield glass as it was the same thickness as the original one that we pulled out of the car and even had the same markings as what the original did. The logo etching was probably the icing on the cake and certainly complimented the rest of the car since if we went with a PPG, the windshield would have been the only incorrect piece of glass on the car. The biggest problem area I had was the upper corners, however, that has always been the problematic area for me whenever I did them. Most likely due to the curvature of the glass. To be honest, I've heard good things about ECS glass from other people. However, I like to see things for myself and besides the crack in the old original glass and the delamination in the corners, you couldn't tell the difference between the two. Kudos to them on making another great product.
When we were just about finished doing the job, my friends neighbor came over to see what we were doing (he owns a 65 Mustang Vert and a 69 Mustang Boss 302 not that I'll hold it against him !) and mentioned to me that he heard of ECS as he had an article saved on his computer pertaining to ECS glass. This was the article he forwarded to me. I never knew the magnitude of information that ECS had about glass.
http://www.mustangandfords.com/how-to/pa...stangs-cougars/
Re: Best glass on the market? [Re: ] #1926010
10/05/15 02:41 AM
10/05/15 02:41 AM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
Yes, I just witnessed ECS windshield glass being installed in a 1970 Cuda convertible with great results too. I was impressed how the glass fit the windshield frame. I also saw what the windshield frame looked like after the windshield trim was installed as well -- and it looked GREAT as well with the gaps being the same as an original setup (not perfect, but acceptable if that makes sense).
Yes, Dave is doing a great job with bringing great products to market -- I bought two windshields after seeing how these fit that 70 Cuda convertible I was so impressed.
Re: Best glass on the market? [Re: ] #1926013
10/05/15 02:46 AM
10/05/15 02:46 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Who makes the ECS glass and where?
Made in the USA!
Re: Best glass on the market? [Re: ] #1926018
10/05/15 02:57 AM
10/05/15 02:57 AM
resq302
resq302
I'm not certain who makes it for ECS but I'd be willing to bet that it is most likely Made in USA.
Re: Best glass on the market? [Re: 1972CudaV21] #1926135
10/05/15 11:45 AM
10/05/15 11:45 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Last I recall it was JRD International, but IIRC, some of the ECS supplied windshields were PPG also...
Re: Best glass on the market? [Re: DAYCLONA] #1927866
10/07/15 06:22 PM
10/07/15 06:22 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
From what I was told, all old mopar glass is imported. PPG for auto glass does not exist any longer, it is PGW. Apparently ECS has a very good vendor, but still imported. Disappointing, but I guess the way of the future.
Re: Best glass on the market? [Re: njmopar] #1928206
10/08/15 09:04 AM
10/08/15 09:04 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I managed a facility that distributed Motor Coach windshields and was starting to get into Auto glass.. ALL of the WS came from Turkey or China.....
Bleeding Brakes, without a helper
by QuickDodge. 05/26/20 08:02 AM
I’m in GOOGLE JAIL and I don’t like it ... !!
by Doc Fiberglass. 05/26/20 07:47 AM
Pool solar cover options
by MI_Custumz. 05/26/20 05:43 AM
'74 Scamp 62,000 Miles $5,500
by VITC_GTX. 05/26/20 12:17 AM
Moparts Recent Posts
Driveshaft Loop ?
by jlatessa. 05/26/20 08:43 AM
New Mecum site "mymecum" has issues
by Mastershake340. 05/26/20 08:37 AM
by AeroMonte. 05/26/20 08:35 AM
Rocker panel install
by Clanton. 05/26/20 08:27 AM
