Wiring Harness Plugs #1924868
10/03/15 01:33 PM
10/03/15 01:33 PM
NY
old340dog Offline OP
NY
While I was working on my Duster this morning, noticed that 2 out of 3 terminals that plug into my bulkhead on firewall have the little plastic clips broken or missing. Since these clips hold the terminal to the bulk head for a good connection.I want to replace or fix the problem before I do have a problem.
Does anyone make the replacement terminals for these in the right size to fit the bulk head?Or is there another way to fix these?
old340dog
Re: Wiring Harness Plugs [Re: old340dog] #1924889
10/03/15 02:05 PM
10/03/15 02:05 PM
Franklin Square, NY
CUDAAR Offline
CUDAAR  Offline
Franklin Square, NY
You may want to try this company. They make modern day connectors, I am not sure about older ones.
http://aeromotive.us/index.html
-Lou
Re: Wiring Harness Plugs [Re: old340dog] #1924902
10/03/15 02:19 PM
10/03/15 02:19 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Look for Packard 56 terminals, that may be the type you need. TIm
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Wiring Harness Plugs [Re: old340dog] #1924907
10/03/15 02:37 PM
10/03/15 02:37 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Wiring Harness Plugs [Re: old340dog] #1924999
10/03/15 04:44 PM
10/03/15 04:44 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
If you mean the Bulkhead Harness Connectors, MegaParts has them.
http://www.megapartsusa.com/products.asp?cat=749
For the Terminals - 56 Series
http://terminalsupplyco.com/Store/Default.aspx?CAT=DEL010&PCAT=54228#Categories
Re: Wiring Harness Plugs [Re: Pynzo] #1925008
10/03/15 05:07 PM
10/03/15 05:07 PM
NY
NY
Thanks for the information. On the Megaparts.com web site I see they list a headlight terminal for my year car.Not sure if this what I need.It looks like mine. The 2 terminals have bad on my car have the wires from the harness on them. Each one plugs into the bulkhead.The snap clip on the terminals are broken or missing. Is what they call the headlight terminal the one I need or is there ones made for plugging into the bulkhead?
old340dog
Re: Wiring Harness Plugs [Re: old340dog] #1925009
10/03/15 05:11 PM
10/03/15 05:11 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Post some pics of what is broken. Plastic pieces are connectors, terminals are the metal spades inside them.
Re: Wiring Harness Plugs [Re: Pynzo] #1925048
10/03/15 05:51 PM
10/03/15 05:51 PM
NY
NY
Hopefully attached are 2 pictures.Notice at the top of the left and center plugs. The black tabs that are suppose to hold the terminal to the block are missing. I need to replace the terminals.Is this possible and are what they call front headlight terminals on megaparts.com what I need?
old340dog
Re: Wiring Harness Plugs [Re: old340dog] #1925068
10/03/15 06:23 PM
10/03/15 06:23 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
These are Connectors. Not Terminals. Top will be the Wiper Motor, middle Engine, Bottom Head Lights. Pull each one and check the corrosion of the Terminals, which are the metal blades.
Re: Wiring Harness Plugs [Re: Pynzo] #1925083
10/03/15 06:39 PM
10/03/15 06:39 PM
NY
NY
The two on the left are the ones with the broken tabs.So what do I do to keep the connectors tight to the bulkhead without them vibrating loose. Can I get replacement connectors?
old340dog
Re: Wiring Harness Plugs [Re: old340dog] #1925094
10/03/15 07:07 PM
10/03/15 07:07 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Bill Evans has them $10 a piece. There were also foam seals from the factory. Bill should have those also.
Re: Wiring Harness Plugs [Re: markz528] #1925105
10/03/15 07:31 PM
10/03/15 07:31 PM
NY
NY
Thanks for the information and help.How do I get ahold of Bill Evans?
old340dog
Re: Wiring Harness Plugs [Re: old340dog] #1926045
10/05/15 07:55 AM
10/05/15 07:55 AM
NY
NY
Does anyone know how to contact Bill Evans?
old340dog
Re: Wiring Harness Plugs [Re: old340dog] #1926070
10/05/15 09:45 AM
10/05/15 09:45 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
What you see on the MegaParts link labeled as Terminals are the Connectors you are looking for. You need to determine which ones to get. Take a real good look at the wiring in your broken connectors. If the wiring is stiff and brittle you may want to replace the entire harness. Year One sells harnesses.
http://www.evanswiring.com
And so does Bill Evans
