Alignment keeps going out - 70 B Body
#1920571
09/27/15 01:28 PM
09/27/15 01:28 PM
Posts: 457 Hightstown, NJ
njdevil2
Hightstown, NJ
I've messed with this multiple times and have had 3 alignments done and the camber keeps going out - negative.
I replaced the 46 year old upper control arms with new powder coated items with new ball joints and bushings - the old ones were totally shot.
Since then, the alignment would last maybe a mile or so, the last drove I felt it, I came out with a left hander from a stop...I felt the thud and then the tires started screaming.
I'm currently rebuilding the old UCAs with new ball joints and bushings. Since its the only thing I've changed, I'm wondering if the new UCAs just wont work....and before everyone asks, yes they are for B Body, I measured both of them twice and compared them with the old UCAs, so, yes they are correct for the application.
I've wasted more time and energy in this one thing...I redid the rear suspension and accomplished more in less time than this front end stuff.
ANY thoughts? I'm ready to farm this out, that's how frustrated I am right now. I'd REALLY like to drive it before Halloween... especially since it sat for 12 long years before I got the divorce done and back in my hands....
1970 road runner Convertible 1 of 179
Re: Alignment keeps going out - 70 B Body
[Re: njdevil2]
#1920600
09/27/15 02:02 PM
09/27/15 02:02 PM
Posts: 704 USA
rftroy
USA
The upper control arm cam bolts need to be torqued to 65 ft-lb. You can't use a box wrench and call it good, you need to get on there with a torque wrench and make sure you get to 65 ft-lb. If not, exactly what you described will happen.
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: njdevil2]
#1920610
09/27/15 02:08 PM
09/27/15 02:08 PM
njdevil2
Hightstown, NJ
I'll check the cams again, they didn't appear to move, I'll mark them and check again. They were torqued, it was a pita, that's for certain. I make sure everything is set and on the ground before it's tightened.
[Re: njdevil2]
#1920615
09/27/15 02:20 PM
09/27/15 02:20 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
The comments above are correct as I do classic Mopar alignments at work. There are a few things you can do to keep the cams tight. I like to put some good grey moly lube on the bolts and the inside of the bushings where the bots go through. De-burring all the cam surfaces and removing the paint from the body where the cams ride also assure once they are torqued they will stay put. I use extra long box wrenches and box end crows feet to ensure everything is tight. Just remember you cant compress painted surfaces correctly!!! Guys always complain about things coming loose on their cars and I can assure you it's usually because they don't clean the painted surface down to bare smooth metal Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: njdevil2]
#1920621
09/27/15 02:25 PM
09/27/15 02:25 PM
Posts: 5,854 ohio
ruderunner
ohio
Cams not tight enough. Make sure there's no rust either. Rust can torque down OK but it will turn to powder and then things get loose again.
Angry white pureblood male
[Re: njdevil2]
#1920723
09/27/15 05:18 PM
09/27/15 05:18 PM
njdevil2
Hightstown, NJ
Nah, I don't have a home shop anymore since the divorce.
It's only strange since I removed the old UCAS and bolted the new ones in. I had no trouble before this. It's a driver and I didn't paint anything and used new bolts and cams. Even with the new stuff it still happened and that's the frustrating part. There definitely isn't any rust there, the bolts were rusty as we're the UCAs. LCAS and new strut rod bushings were in the plan, but I wanted this done first. I know LCAS are a pita, and that's one thing I'm not doing on the floor of the garage.
[Re: njdevil2]
#1920735
09/27/15 05:38 PM
09/27/15 05:38 PM
Posts: 704 USA
rftroy
USA
Where did you get the upper control arms? What brand are they? Just a possibility, but if the bushings in the aftermarket arms are too short you could be putting a lot of torque into distorting and bending the UCA brackets on the frame, and not getting good clamping on the bushings.
Since we don't know what you're working with, you should probably compare the bushing length to the stock ones. If that's OK, then everything said above is the best advice.
Bob
[Re: njdevil2]
#1920966
09/28/15 12:30 AM
09/28/15 12:30 AM
njdevil2
Hightstown, NJ
I got the arms from a rebuild in the Midwest.
The bushings were the same length and fit snug when installed, again, measured and compared before I installed.
I'll check it this week....
