Re: Field wire keeps burning up1973 plymouth
[Re: Paul_Fancsali]
#1920294
09/26/15 10:41 PM
09/26/15 10:41 PM
RapidRobert
Paul, more detail on how you have it wired & which wire(s) are getting hot/burning up. You have the blue 732 (iirc) reg?
[Re: Paul_Fancsali]
#1920297
09/26/15 10:47 PM
09/26/15 10:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Either there is too much current thru the wire (short) or the wire is undersized.
You post is a bit confusing though. Is the measured voltage at the battery 13.9-14.2 at idle or is the alternator supposed to be regulated to 13.9-14.2V? What is this relay you speak of and how is it wired?
[Re: Paul_Fancsali]
#1920338
09/26/15 11:49 PM
09/26/15 11:49 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
A shorted field in the alternator can cause too much current to be flowing in the field wires. The voltage output can still be okay.
[Re: Supercuda]
#1920341
09/26/15 11:51 PM
09/26/15 11:51 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
The field wire is only supposed to see switched 12 volt power from the run side of the ignition switch to energize the alternator, the power coming out of the big terminal on the alternator needs to go the battery post at the starter relay terminal and not through the ammeter (if you still have one)
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1920352
09/27/15 12:11 AM
09/27/15 12:11 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The field wire is only supposed to see switched 12 volt power from the run side of the ignition switch to energize the alternator, the power coming out of the big terminal on the alternator needs to go the battery post at the starter relay terminal and not through the ammeter (if you still have one) If its still the stock setup then the alt output from the output wire does go back through the ammeter. If its been modified it may not as that gets changed most of the time when modified. But I agree we need more details so we can be sure if your talking about one of the field wires or the alt output wire. Does it use an electronic voltage reg or mechanical ? Ron
[Re: Paul_Fancsali]
#1920373
09/27/15 12:42 AM
09/27/15 12:42 AM
RapidRobert
trying to grasp if the constant output reg is overcharging but people have used them with no probs or if something is dead shorted in the field circuit (I'm thinking that) making the alt overcharge
[Re: Paul_Fancsali]
#1920458
09/27/15 09:34 AM
09/27/15 09:34 AM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
Happened to me and the culprit was the plastic isolator on the alternator's power terminal. It failed and was grounding itself out on the housing.
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
[Re: Paul_Fancsali]
#1920687
09/27/15 04:04 PM
09/27/15 04:04 PM
Posts: 10,732 North Dakota
6PakBee
North Dakota
ammeter is by passed the wiring burned is blue field wire that is connected to top term of alt the battery output wire is getting hot also. Thanks for the replies and keep them coming Sounds like the alternator is at maximum output.
[Re: Plum440]
#1922624
09/30/15 06:24 PM
09/30/15 06:24 PM
Posts: 1,687 Boston, MA
crocha617
Boston, MA
Happened to me and the culprit was the plastic isolator on the alternator's power terminal. It failed and was grounding itself out on the housing. That happened to me as well burned all the way up the column. Brand new alternator must have been a return that someone messed with before I got it. Field terminal was grounding on the housing I think.
[Re: crocha617]
#1923387
10/01/15 03:31 PM
10/01/15 03:31 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Happened to me and the culprit was the plastic isolator on the alternator's power terminal. It failed and was grounding itself out on the housing. That happened to me as well burned all the way up the column. Brand new alternator must have been a return that someone messed with before I got it. Field terminal was grounding on the housing I think. Same thing here , melted the wires right up the the ammeter , bare wires eventually were shorting out under the dash.
