Re: Let's hear some W7,W8,and W9 builds
[Re: 340_Dart]
#743297
12/29/11 06:55 PM
12/29/11 06:55 PM
Posts: 2,423 Ambridge, Pa.
rickraw
Ambridge, Pa.
mine's a 440sb, 4"x 4.185 diamond pistons 11-1, w9's by ryan, 730 roller by bullet cams, callies crank, compustar rods, m1 intake, prosystems 1050 domy. best so far- 9.61@137.91 with some trans slippage. street ride. seeya.
[Re: Uncle Barry]
#743303
12/29/11 11:00 PM
12/29/11 11:00 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Sold the CFE W8's but....
421 SB R3 358 WC block Crower Ultralite crank 3.8" stroke GRP rods Diamond pistons Bullet roller cam Single four barrel cast intake
Best ET it ran 5.69
Best honest MPH 125 had a no name track that showed 128 but, I called BS.
The block has been tested due to an undetermined leak and no trouble was found in the questionable cylinder. The heads are sold sense then the block and intakes are in the for sale section. Could be somebodies lucky day.
Leon
[Re: Uncle Barry]
#743304
12/29/11 11:19 PM
12/29/11 11:19 PM
Posts: 159 australia
charger410
australia
Ex sprintcar engine from Us in my Chug. 410in 4.15 x 3.8 A8 block solid roller 268/50 780lift W9 heads, titanium valves, pac springs, jessel rockers JE pistons Carrilo rods Bryant Crankshaft Barns 4 stage dry sump Injecter stacks 1 7/8 step into 2inch pipes Dyno 875hp 652fbs Been running for 4years never touched the engine besides plugs and oil Have only done street events on slippery tracks but will take it to the local 1/4mile track and see how it goes in a week and will post my time here good or bad
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
[Re: charger410]
#743305
12/30/11 11:12 AM
12/30/11 11:12 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
9" R3 3.79 Callies 4.185 bore MGP rods 13.8 static 55mm cam 15* Coleman/Arrington W8 420 intake SV-1 3 step header w/Burns merge External wet sump 894hp-657tq Built to spray a little, but decided to go N/A. Car is now finished just in time for the bad weather. We will run this engine for one season before selling it and doing a full N/A build.
[Re: fishy340]
#743309
12/30/11 07:47 PM
12/30/11 07:47 PM
Leon441
Lynchburg, VA
Hey Jim, who makes the 55 mm cam core?
Leon
[Re: fishy340]
#743310
12/31/11 09:52 AM
12/31/11 09:52 AM
jim sciortino
Trumbull,CT.
very impressive boys! and jim you can put your motor on the ferry i'll pick it up on the other side somewhere in suffolk county
Go to an ATCO rent day and take it right out of the car.
[Re: Leon441]
#743311
12/31/11 09:55 AM
12/31/11 09:55 AM
jim sciortino
Trumbull,CT.
Leon
Dean just gave me a slap. It's a 50mm.
I should really re-read before I post.
[Re: jim sciortino]
#743312
12/31/11 04:13 PM
12/31/11 04:13 PM
Posts: 3,456 Out West
408strokerdart
Out West
894hp-657tq
Almost a clone to mine....why is mine such a turd by comparison? Hey Jim, could you share some cam/valvetrain specs on your build? PM if you want. No offense to any others, but this an impressive build for the power output. I am sure I am 100 hp less with almost the same combo and more compression.
[Re: 408strokerdart]
#743313
12/31/11 07:37 PM
12/31/11 07:37 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
894hp-657tq
Brian, I was thinking the same thing. Mine is very similar as well. I'm sure my combo is giving up some hp with the nitrous camshaft but 100 hp?
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#743314
12/31/11 09:07 PM
12/31/11 09:07 PM
408strokerdart
Out West
894hp-657tq
Mike Gray
Yes Mike....ours are very similar as well. What is Jim doing so right that we are doing so wrong for the difference in hp? I can understand mine being slightly quicker than yours in (N/A) because I don't have a nitrous cam, but ours are pretty equally paired. I know Jim has beaten on his on the dyno for a long time and is wringing it out pretty good.
#743316
01/01/12 06:59 AM
01/01/12 06:59 AM
Posts: 426 Cairns Queensland Australia. T...
vc360
894hp-657tq
I would say cylinder head/manifold/carb. Mine picked up 100hp with a head change and another 30 after the dyno with more carb work.
4.100 x 4.00 stroke Chapman w9 with 772 intake opened for a dominator. 754hp/615ftlbs. In my 3520lb barracuda has run a best of 9.66 at 138.6mph.
