Field wire keeps burning up1973 plymouth #1920263
09/26/15 09:31 PM
09/26/15 09:31 PM
P
Paul_Fancsali Offline OP
P
Been having a issue with my 73 sat keep burning up my field wire over the engine this past time I had it done at a shop assuming I was doing something wrong Today it is once again fried the wire to battery is hot but you can hold it and the wiring near the bulk head is hot after just 15 minutes was told the alternator could be the cause but it is steady 13.9-14.2 constant output regulator I have checked into all the wiring as some had smoked in the bulkhead connector. changed it out and went with using straight from relay where needed any idea's where to look besides the alt I will check starter wires too Thanks!
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1920294
09/26/15 10:41 PM
09/26/15 10:41 PM
Paul, more detail on how you have it wired & which wire(s) are getting hot/burning up. You have the blue 732 (iirc) reg?
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1920297
09/26/15 10:47 PM
09/26/15 10:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Either there is too much current thru the wire (short) or the wire is undersized.
You post is a bit confusing though. Is the measured voltage at the battery 13.9-14.2 at idle or is the alternator supposed to be regulated to 13.9-14.2V? What is this relay you speak of and how is it wired?
Don't be the exception.
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1920338
09/26/15 11:49 PM
09/26/15 11:49 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
A shorted field in the alternator can cause too much current to be flowing in the field wires. The voltage output can still be okay.
Re: Field wire keeps burning up1973 plymouth [Re: Supercuda] #1920341
09/26/15 11:51 PM
09/26/15 11:51 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The field wire is only supposed to see switched 12 volt power from the run side of the ignition switch to energize the alternator, the power coming out of the big terminal on the alternator needs to go the battery post at the starter relay terminal and not through the ammeter (if you still have one)
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Field wire keeps burning up1973 plymouth [Re: Polarapete] #1920352
09/27/15 12:11 AM
09/27/15 12:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If its still the stock setup then the alt output from the output wire does go back through the ammeter. If its been modified it may not as that gets changed most of the time when modified.
But I agree we need more details so we can be sure if your talking about one of the field wires or the alt output wire. Does it use an electronic voltage reg or mechanical ? Ron
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1920359
09/27/15 12:22 AM
09/27/15 12:22 AM
P
P
ammeter is by passed the wiring burned is blue field wire that is connected to top term of alt the battery output wire is getting hot also. Thanks for the replies and keep them coming
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1920373
09/27/15 12:42 AM
09/27/15 12:42 AM
trying to grasp if the constant output reg is overcharging but people have used them with no probs or if something is dead shorted in the field circuit (I'm thinking that) making the alt overcharge
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1920386
09/27/15 12:52 AM
09/27/15 12:52 AM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
If its the old style alternator one of the fields is grounded or maybe one of the fields on the alternator has a bad isolator on a brush screw. With both field wires disconnected check if they are going to ground with a meter & car not running
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1920458
09/27/15 09:34 AM
09/27/15 09:34 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
Happened to me and the culprit was the plastic isolator on the alternator's power terminal. It failed and was grounding itself out on the housing.
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1920687
09/27/15 04:04 PM
09/27/15 04:04 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Sounds like the alternator is at maximum output.
Re: Field wire keeps burning up1973 plymouth [Re: 6PakBee] #1920802
09/27/15 07:54 PM
09/27/15 07:54 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
It will charge wide open if the green field wire or lug is going to ground which is how the voltage regulator works by variable resistance to ground,
I did have a regulator that would charge wide open one time also
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1920973
09/28/15 12:46 AM
09/28/15 12:46 AM
P
P
Replaced both alt and reg with OE stock. I also ran amp test on fuel pump 3 amp and replaced and grounded every thing I could get to even the starter I will update in next couple days
Re: Field wire keeps burning up1973 plymouth [Re: Paul_Fancsali] #1922597
09/30/15 05:58 PM
09/30/15 05:58 PM
P
P
Well as of now changed out alt and reg { Might as well be a part changer besides I have the stuff in stock} I rewired the field wire with heavier gauge wiring . I'll let you know {weather stinks } Thanks for help folks!
Re: Field wire keeps burning up1973 plymouth [Re: Plum440] #1922624
09/30/15 06:24 PM
09/30/15 06:24 PM
Boston, MA
crocha617 Offline
crocha617  Offline
Boston, MA
That happened to me as well burned all the way up the column. Brand new alternator must have been a return that someone messed with before I got it. Field terminal was grounding on the housing I think.
Re: Field wire keeps burning up1973 plymouth [Re: crocha617] #1923387
10/01/15 03:31 PM
10/01/15 03:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Same thing here , melted the wires right up the the ammeter , bare wires eventually were shorting out under the dash.
