Re: Caltracs vs. Assassin?
[Re: DLewis]
#1920210
09/26/15 07:37 PM
09/26/15 07:37 PM
Posts: 4,457 Washington
madscientist
Washington
The Asassin has more adjustability. That's usually a good thing, unless you don't test. Then it may be a bad thing.
[Re: DLewis]
#1920457
09/27/15 09:30 AM
09/27/15 09:30 AM
Posts: 2,937 A shed in England
Tig
A shed in England
As above, we drilled extra holes in our Caltrac spring mounts and had different front plates made to alter the lower bar position. Ended up back at the stock positions any way. However, if I were to do it again I'd go with the Assassin bars.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1920482
09/27/15 10:50 AM
09/27/15 10:50 AM
Posts: 103 Minnesota
DLewis
Minnesota
As above, we drilled extra holes in our Caltrac spring mounts and had different front plates made to alter the lower bar position. Ended up back at the stock positions any way. However, if I were to do it again I'd go with the Assassin bars. Thanks guys, I'll give them a shot. Tig, Are there leafs you'd recommend?
[Re: DLewis]
#1920590
09/27/15 01:53 PM
09/27/15 01:53 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
These bars (caltrac or assassin's) basically make the front spring segment stiff on launch, essentially turning them into a very short ladder bar.
There is very little time between trans brake release, pinion rotation, and when the bars do that job.
The only major influence the bars adjustment holes have is to change the time it takes for that segment to become stiff.
If you put the rear hole higher or the front hole lower, it requires more pinion rotation before the pin hits the top of the spring. More rotation = more time.
On most cars with decent power you want this to happen as quick as possible so you can hit the tire, and get the car moving.
There is a much bigger effect on how high the front spring mount is off the ground, then there is anything you will adjust with the caltrac adjustment.
[Re: dizuster]
#1920657
09/27/15 03:10 PM
09/27/15 03:10 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) and would like to add Calvert supports a number of classes in different series with contingency. His checks cash with no B.S.
"Just a Bracket car dressed up like a streetcar"
[Re: DLewis]
#1920672
09/27/15 03:31 PM
09/27/15 03:31 PM
Tig
A shed in England
As above, we drilled extra holes in our Caltrac spring mounts and had different front plates made to alter the lower bar position. Ended up back at the stock positions any way. However, if I were to do it again I'd go with the Assassin bars. Thanks guys, I'll give them a shot. Tig, Are there leafs you'd recommend? The split mono leaf that the Calvert Bars use , I think they may be supplied by Landrum. I'd also add that Calverts after sales help is very good too. We had our mono spring re-arched to clear the slicks and hit the tyre hard so we tried to slow it down some by altering the lower bar angles and leverage.
