Re: Tunnel Ram and fuel slosh issues ? [Re: Tig] #1895440
08/19/15 04:33 PM
08/19/15 04:33 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Another q, Does anyone run jet extensions with these floats? All the floats are notched so do I need 'em?
Re: Tunnel Ram and fuel slosh issues ? [Re: Tig] #1895515
08/19/15 06:46 PM
08/19/15 06:46 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I don't
Re: Tunnel Ram and fuel slosh issues ? [Re: Tig] #1919946
09/26/15 09:16 AM
09/26/15 09:16 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Still got issues, also my AFR's change with each gearchange. Usually in the 10's in first 11's in second and 12's in 3rd. Steps coincide with gearchanges.
Re: Tunnel Ram and fuel slosh issues ? [Re: Tig] #1919970
09/26/15 10:38 AM
09/26/15 10:38 AM
Jerry Kathe Offline
Jerry Kathe  Offline
You have tunnel ram floats with jet extension notches?
Re: Tunnel Ram and fuel slosh issues ? [Re: Jerry Kathe] #1920455
09/27/15 09:26 AM
09/27/15 09:26 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi Jerry. Yes we got these and tried them. Still all sorts of weird issues with fueling. I'm guessing we need to seal the carbs to the scoop and run a decent air filter before we can get to grips with it.
Our season is finished now lots of work to be done on the car before it's next out, modifying they scoop is one of them.
Re: Tunnel Ram and fuel slosh issues ? [Re: Tig] #1920469
09/27/15 10:07 AM
09/27/15 10:07 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Hello Tig. You shouldn't have floats with notches, you need floats that are shaped like a wedge on one end, these will be orientated left and right with the wedge facing reward. I have never seen tunnel ram floats with jet extension notches and wedge features on the same float. Jet extensions are not necessary (or desired) with sideways mounted carburetors. I would go back and visit that before trying anything else.
Re: Tunnel Ram and fuel slosh issues ? [Re: Jerry Kathe] #1920477
09/27/15 10:37 AM
09/27/15 10:37 AM
N.E. Ohio
OhioGTX Offline
OhioGTX  Offline
N.E. Ohio
Interesting Topic. I have been running a tunnel ram for the past 6 years and experienced a similar set of circumstances a few years back. I had been running with zero problems and then changed cylinder heads to E-Victors. The change moved the carbs very close to the six pack scoop. The Car would launch hard but then a strong bog/failure about 40 feet out. What I found was a simple fix, I removed the hood, exposing the carbs with no restriction above them, the problem resolved immediately. Since then I have been running a flat hood with a halibrand style scoop. No more problems.
I have standard 4150 bowl floats with no jet extensions. Floats are set a little high but nothing radical. No way to say this is the problem you are experiencing, but it is a simple experiment to determine.
As a side note, I came across the idea of removing the hood after talking with very well known local pro-stock carb builder. His rule of thumb was simple, you should be able to place your fist between the carb and the top of the scoop, if not, your experiences may vary.
68 GTX, 9.38 at 144, Best Machine 540..
Re: Tunnel Ram and fuel slosh issues ? [Re: Tig] #1920631
09/27/15 02:34 PM
09/27/15 02:34 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I also had the same problem on my Dart with a hemi scoop took it to the track with a dominator on top of 2" adaptor and victor intake, did 3 runs, first was 121, so i jetted up a couple, the next 2 were 122, on the same day i swapped my old 950 with 2" supersucker back on and it picked up 5 mph the next 2 runs. Ran the car without the hood next time out with the dominator back on and it ran it's best ever speed.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Tunnel Ram and fuel slosh issues ? [Re: Jerry Kathe] #1920666
09/27/15 03:20 PM
09/27/15 03:20 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
The floats have wedges and are fitted so the wedge is to the rear, they also have notches for jet extensions. They are not the same as the ones linked to at the start of the thread. http://www.quickfueltechnology.com/fuel-bowl-parts/nitrophyl-float-wedge-primary.html
Pretty sure my hood is causing a problem as we can only just get a 2 1/2 inch tall filter in there. We have filter tops too which are real close to the hood.
Re: Tunnel Ram and fuel slosh issues ? [Re: Tig] #1920742
09/27/15 05:54 PM
09/27/15 05:54 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
If it's lift off do a run without the hood and the filters, if it cures the problem then get some less restrictive filters and fit a different scoop.
Mick
best 60ft 1.36
Re: Tunnel Ram and fuel slosh issues ? [Re: Tig] #1920750
09/27/15 06:16 PM
09/27/15 06:16 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
My Dart does the same thing. Leaves hard then falls. I'm going to try some of the above mentioned fixes. I tried the hose between the bowl vents and it helped some, but didn't get rid of all of the bog.
One major problem is carb to scoop clearance. I only have about 2" above the top of the carbs and run two short about 4" round air cleaners.
