1962 D-200 #1919438
09/25/15 01:36 PM
09/25/15 01:36 PM
Martin TN
ridin98ci Offline OP
Martin TN
Well I finally got the 62 home (225 slant six, 4speed)....the tires are TRASH!!! 17.5 inch wheel....I have NO idea where to get affordable tires for the thing....the only thing I can find are $300-$400 trailer tires...also I am in DIRE need of a carb....this thing just POURS gas out....any idea where to get a good deal on a single throat carb for a 225?
LOUD AND PROUD!!!
Re: 1962 D-200 [Re: ridin98ci] #1919474
09/25/15 02:14 PM
09/25/15 02:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just rebuild the carb. It's super easy. You could also try tapping on the top of the carb where the fuel line hooks up. It sounds like a basic needle and seat not sealing.
Re: 1962 D-200 [Re: ridin98ci] #1919483
09/25/15 02:22 PM
09/25/15 02:22 PM
Martin TN
Martin TN
I have done the tapping trick....Ive tried rebuilding carbs and I have NEVER had any luck....its pouring out every gasket....garbage
LOUD AND PROUD!!!
Re: 1962 D-200 [Re: ridin98ci] #1919494
09/25/15 02:46 PM
09/25/15 02:46 PM
dogdays Offline
dogdays  Offline
http://ricksontruckwheels.com/tires-175-truck.php
These are all truck tires, not trailer. Tire Rack has the Yokos for about $1400 a set.
I'd be thinking about switching to 17s or 18s.
A 10.5 wide tire fits under the front, and an 11.5" wide tire fits under the back. Both if you have the right back spacing.
R.
Re: 1962 D-200 [Re: ridin98ci] #1919733
09/25/15 09:04 PM
09/25/15 09:04 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
great looking truck!
1981 Dodge D150 360 auto
Re: 1962 D-200 [Re: ridin98ci] #1919775
09/25/15 10:33 PM
09/25/15 10:33 PM
Bellingham,WA
Dad's '74 D100 Offline
Bellingham,WA
Nice solid looking truck.If it sat for awhile you most likely have a carb float that's ruptured if brass or absorbed fuel if the foam close cell type and has become too heavy.Another quick and easy thing to try is pinch off the rubber line fuel or remove the line at the inlet at the carb and plug it. Run the carb dry,until it dies then reattach the line and fire it back up. If there is a speck of dirt in the needle and seat this will many times flush it through and may solve the problem. Truth is you couldn't find a much simpler carb to rebuild.
Re: 1962 D-200 [Re: ridin98ci] #1919811
09/25/15 11:13 PM
09/25/15 11:13 PM
Lehigh Acres, Florida
rickstershemi Offline
Re: 1962 D-200 [Re: ridin98ci] #1919872
09/26/15 12:58 AM
09/26/15 12:58 AM
Tampa Bay,Fl.
mopargreg Offline
mopargreg  Offline
Tampa Bay,Fl.
VEE EIGHT TIME.....OH YEAH
Re: 1962 D-200 [Re: mopargreg] #1919919
09/26/15 03:24 AM
09/26/15 03:24 AM
Martin TN
Martin TN
come get it....I have to many irons in the fire to do that....I just wanna get it running and driving good....enjoy it a little and then pass it on to some one else
LOUD AND PROUD!!!
Re: 1962 D-200 [Re: rickstershemi] #1919920
09/26/15 03:26 AM
09/26/15 03:26 AM
Martin TN
Martin TN
Originally Posted By rickstershemi
Thanks....I am on it
LOUD AND PROUD!!!
Re: 1962 D-200 [Re: ridin98ci] #1920090
09/26/15 02:44 PM
09/26/15 02:44 PM
Bellingham,WA
Bellingham,WA
From the ebay ad....This carb is old stock from an auto parts warehouse. You or a carburetor repair specialist LIKELY WILL need to clean and refurbish it a bit...AGAIN, it was re-manufactured over 25 years ago and has been sitting in storage ever since..."common sense"...it may need to be re-conditioned. THERE IS NO GUARANTEE OR WARRANTY and THERE IS NO RETURNS... Locate a local shop to do the rebuild so that you have some recourse. There are only 2 reasons for the flooding..1) dirt stuck in or damaged needle and seat...2)a float that has become heavy and sank to the bottom. That's it. As a former ASE master tech & shop owner for 30+ yrs (now retired sort of), I hate to see people spend monies needlessly.
Re: 1962 D-200 [Re: Dad's '74 D100] #1920173
09/26/15 06:37 PM
09/26/15 06:37 PM
The OP stated that fuel is coming out of all the gaskets....that is not an indication of a stuck float, needle/seat .... It sounds to me like it's beyond repair and for the cheap this one is listed for...I for sure would take a shot....have had good luck in the past...just MHO smile
Re: 1962 D-200 [Re: ridin98ci] #1920191
09/26/15 07:08 PM
09/26/15 07:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
First thing I would try is tightening the carb body screws. Those one bbls had a habit of loosening up. A hundred bucks is not a cheap crap shoot. It would be pretty hard for that one bbl to be beyond repair. The carb has less then 10 moving parts so I think I'd try rebuilding it myself by closely following the instructions and seeing if there might be an online video to help. It's a very easy carb to do. shruggy
Re: 1962 D-200 [Re: rickstershemi] #1920360
09/27/15 12:23 AM
09/27/15 12:23 AM
Bellingham,WA
Bellingham,WA
Yes, gas would come out of every gasket as well as the lower throttle shaft with a sunk float or dirt in the needle & seat or damaged needle tip. I didn't say a stuck float but a float that has sprung a leak and filled with fuel if brass or become saturated with fuel and again become heavy and never shuts out the flow of fuel because the needle and seat remain open.A sunk float Think of a toilet tank float stuck in a down position and the water continues running. Same toilet but the chain gets stuck under the flapper in the bottom and you end up with a running water. That is the same principal and function of the needle and seat in a carb.If there is trash in the seat it will never get flushed through normal running. I've done this many,many times and it is quick. Run the carb dry by cutting off the fuel supply.After reconnecting the incoming rush of fuel will flush the trash into the fuel bowl. The rig in my avatar log over a 100,000 miles going border to border / coast to coast and have done this trick along the roadside for other rodders. I learned to carry a filtering funnel on our cross country treks.These are the only 2 reasons that will cause the symptoms the op described.
As Stumpy says this thing only has a few parts and is an easy build. I'm new here and don't mean to bump shoulders with anyone but I'm not new to the craft. I would gladly offer to rebuild the op's carb with a provided kit / postage and I'll stand behind it. I don't expect him to but it is a sincere offer. If he$$ bent on spending money why not support a local shop to do a rebuild on your,most likely, original carb.
Re: 1962 D-200 [Re: ridin98ci] #1920677
09/27/15 03:43 PM
09/27/15 03:43 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
6 bolt or 8 bolt wheels? shruggy My 62 W200 had 8 bolt wheels but all my D300's have 6 bolt wheels. work
JB Rhinehart, Realist
A-Body's RULE!
Re: 1962 D-200 [Re: Dad's '74 D100] #1920836
09/27/15 09:14 PM
09/27/15 09:14 PM
I'll just leave it to the experts.....I guess owning a carb and fuel injection rebuild company for 10+ years doesn't carry much weight...LOL
Rickster
Re: 1962 D-200 [Re: ridin98ci] #1920887
09/27/15 10:44 PM
09/27/15 10:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sunk float or dirt in the needle and seat both will cause the indicated leakage. I've been rebuilding various brands of carbs for better than 50 years so I guess my word might mean a little something.
Re: 1962 D-200 [Re: Rhinodart] #1921036
09/28/15 05:08 AM
09/28/15 05:08 AM
Martin TN
Martin TN
8 lug.....I wanna find something that looks stock-ish....bling wont look right on the truck.
Also for the carb fight....I got a carb off a 61 Dart with a slant six....I even rebuilt it.....the old one was JUNK....no saving it.....so onto other issues....she is running great now....I have an issue with the hydraulic clutch....push the pedal in and it doesn't want to come back up by its self.....any advice?
LOUD AND PROUD!!!
Re: 1962 D-200 [Re: ridin98ci] #1921044
09/28/15 08:00 AM
09/28/15 08:00 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you have 8 bolt wheels, any of the older, factory style 8 bolt 16 1/2" or 16" (or the old 15" 8 bolts that are very hard to find) wheels off a Dodge truck will bolt on, and with a decent size tire will look right.
I think, with the clutch pedal, I would take a look under the dash and make sure the pedal itself isn't dragging against anything. Wouldn't hurt to check the linkage at the bell housing either. Most of that old stuff had grease zerks everywhere, if the greased parts haven't been moved for a while, the grease could have gotten pretty stiff and hard. A good cleaning & re-greasing might do wonders. (I think I would check all the greased things on the truck, a couple pumps of fresh grease might make a lot of things work better/more smoothly).
Past the hard grease or binding pedal, the next likely shot is the clutch cylinder rebuild or replacement. Gene
Re: 1962 D-200 [Re: ridin98ci] #1921198
09/28/15 02:30 PM
09/28/15 02:30 PM
Bellingham,WA
Bellingham,WA
Glad to hear you got it running well but I didn't think we were fighting just a little friendly disagreement. Now if you want to see a fight wait until I figure out how to post photos of our project '74 D100 Custom shortbed stepside that we are getting ready to drop in a chevy 427 w/M22 4spd. grin
On the hyd. clutch check the slave cylinder and from inside the passenger compartment check the firewall for seepage trails from the master cyl.
Now before a lynch mob is formed that was a joke.There will be no cross breeding to the D100, not that there's anything wrong with that.
