Re: Sounded like a lifter tick but now it louder?
[Re: ahy]
#1919302
09/25/15 08:57 AM
09/25/15 08:57 AM
Posts: 304 Wisconsin
Big D A12
Wisconsin
Sounds like a push rod came out and is lying in the valley. I have had this happen, no idea how it happens, but it sounds terrible. Take the valve cover off and it will be obvious which one it is.
Hope this helps.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: 79machocharger]
#1919670
09/25/15 07:22 PM
09/25/15 07:22 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If you dropped a push rod the lifter will be tossed out of the bore and you'll lose oil pressure to the top end of the engine.
Been there. Done that.
#1919773
09/25/15 10:33 PM
09/25/15 10:33 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
It could be just a collapsed lifter, Had that happen before on a new 383 Roadrunner.
