Re: 518 to OD833 behind my BB 86 RC
[Re: CTD5.9]
#1889978
08/12/15 12:49 AM
08/12/15 12:49 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
so did that 833 come off a chevy diesel truck?----i have never heard of one on a dodge unit as a 4x4 setup.... I downloaded the picture, looks like a car/2wd 833 to me Correct........ more pictures this week as I get the column back together.....with new grant wood steering wheel to match the pistol grip shifter and Pentastar horn button.
Moparlee
[Re: dogdays]
#1898132
08/24/15 02:16 AM
08/24/15 02:16 AM
Posts: 2,042 colorado
savoy64
colorado
Wow, never knew that! So bolting an A-833 behind your 350 is possible with factory parts. ----i found the thread on this gm bell housing----it is an 82-84 6.2 dual pattern #14061655----this makes it happen for the 833.....
[Re: WO23Coronet]
#1899707
08/26/15 01:01 PM
08/26/15 01:01 PM
Robbins
Joplin, MO USA
Is that a BB bell housing made for the bigger bearing retainer on the OD trans or did you have to machine the bell housing? It's a factory dual pattern bell for a truck four speed and the OD833, but you could put any 833 four speed with the correct ring.
Moparlee
[Re: savoy64]
#1899714
08/26/15 01:05 PM
08/26/15 01:05 PM
Robbins
Joplin, MO USA
and robbins limit your power displays to first and second gear---3rd and 4th are somewhat weak due to being reversed in order on the mainshaft----passon sells a hemi cut gearset for the 833od that is good to 750hp---one of my friends runs one at the dragstrip in a blown stroker 440 with no problems in 5 years---loves it as he can drive on the highway at fairly normal rpms..... I'm really not going to be hot rodding this thing around....ya I wouldn't mind getting that kit.....but to be honest..... I'd rather have his five speed.....and with my change over.... I can go that way when I get rich....lol
Moparlee
[Re: Robbins]
#1899722
08/26/15 01:19 PM
08/26/15 01:19 PM
Robbins
Joplin, MO USA
The flywheel that I got from a member and the clutch package from Brewer's Performance.
Moparlee
[Re: Robbins]
#1899807
08/26/15 03:36 PM
08/26/15 03:36 PM
Robbins
Joplin, MO USA
Brewer's Performance....rebuilt a shift box for me and made it a bolt on shifter for the Pistol Grip.
Moparlee
[Re: Robbins]
#1900459
08/27/15 03:45 PM
08/27/15 03:45 PM
Robbins
Joplin, MO USA
You can still get a new rod that goes threw the firewall.....thanks Jim.
Moparlee
[Re: savoy64]
#1906069
09/04/15 12:32 AM
09/04/15 12:32 AM
Robbins
Joplin, MO USA
the guy that told me about them said that some had the chevy bolt pattern and some had the dodge pattern---the bellhousing for the dodge one is pretty rare as chevy guys didnt know what they looking at... I've seen a two wheel drive one out of cheby on the floor at a friends place (back in the 90's) and it had the Mopar bellhousing pattern.
Moparlee
[Re: Robbins]
#1910290
09/10/15 11:38 PM
09/10/15 11:38 PM
Robbins
Joplin, MO USA
I got a bracket from Schumacher(?).....I hope it works.....hopefully it'll let me keep the 518 cross member.
Moparlee
