Dodge v10 timing chain #1917874
09/23/15 02:43 AM
09/23/15 02:43 AM
Nashport, OH
chargers777 Offline OP
Nashport, OH
What is the service life and does it have a tensioner.Is it also a double row chain.My truck has 85,000 miles and I think I hear some chain noise.Its a 98.
Re: Dodge v10 timing chain [Re: chargers777] #1917877
09/23/15 02:56 AM
09/23/15 02:56 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
No tensioner standard 2 gears and a chain. No service till there is a problem. I would check other things first, the chains wear good and seldom cause a problem.
Re: Dodge v10 timing chain [Re: SALEM1912] #1918568
09/24/15 02:14 AM
09/24/15 02:14 AM
Nashport, OH
Nashport, OH
I bad dropped the pan and the chain seemed loose. Will these bend valves if they jump a tooth.How long does it take to change or do you think it is OK with some play in it.
Re: Dodge v10 timing chain [Re: chargers777] #1919967
09/26/15 10:33 AM
09/26/15 10:33 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
As per Alldata it's about a 5 hr job. 1/8 inch play is the limit
