Re: A833 grinds sometimes going into 2nd
[Re: Finoke]
#1916448
09/21/15 12:10 AM
09/21/15 12:10 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Well when you mix parts you might wind up with compatibility problems. Some syncro rings are different , this may be your problem. Look on the Brewer Performance web site to see if you used the correct parts.
[Re: Finoke]
#1916464
09/21/15 12:41 AM
09/21/15 12:41 AM
RapidRobert
But it wants to grind most times going into 2nd unless I baby it and double clutch. My stick knowledge is extremely limited but the synchro not grabbing enough/worn out/cone issue there would be just a guess. Gonna live with it or open it up? Was it completely gone thru back when
[Re: Finoke]
#1916472
09/21/15 12:49 AM
09/21/15 12:49 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Converted to OD means what?
There are no stock 18 spline OD transmissions. Unless you bought one of Passon's OD kits, which should have had new synchros IIRC, sounds like someone stuck used guts in your case, which probably means you need synchros.
[Re: Finoke]
#1916564
09/21/15 09:20 AM
09/21/15 09:20 AM
Posts: 1,567 Ky
jt4406
Ky
should be in the upper hole instead of the lower hole This will only change the distance the shift handle has to move to put the transmission in gear, and the front lever is for 3-4 gear (or technically 3rd-OD for the converted trans). If it rakes in second, but shifts smoothly in all other gears and your clutch is adjusted correctly, PULL IT OUT , it's got to come apart to fix it. Just my 2cents.
Yeah, it's hopped up to over 160...
[Re: Finoke]
#1916592
09/21/15 10:43 AM
09/21/15 10:43 AM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
The 3/4 lever being positioned down is because of the way they changed things around to achieve the overdrive setup. The OEM overdrive gear set used what was 4th gear for 3rd and 3rd became the 4th gear which was cut to be less than 1:1, so overdrive. I understood this change in loading necessitated the larger input shaft bearing.
I don't believe that would affect the 1/2 shifting. If something was out of position 'up front' because of the lever being incorrect, that should affect your trying to go into 3rd. If it was badly out of position you'd be having problems all the time and even moving the shifter across the H pattern would be difficult, because you'd be fighting the detents in the side cover mechanism.
Jamie will be much smarter about this than I. Hope you get it sorted out.
Lead, follow or get the hell out of the way
[Re: Finoke]
#1916660
09/21/15 12:37 PM
09/21/15 12:37 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
If it's just second gear Id go after the synchro. Here is my favourite method for checking clutch for disengagement. While idling press clutch pedal down for 5 seconds. This give time for disc to stop spining. Engage reverse. No grind means clutch was fully disengaged.
Another thing to consider. The 833 OD was essentially a 1st, 3rd, direct and OD. So a speed shift from 1 to 2 was actually 1 to 3rd which is a super wide ratio change, hence a big rpm change for the synchro to deal with.
[Re: Magnum]
#1916684
09/21/15 01:22 PM
09/21/15 01:22 PM
Supercuda
About to go away
About to go away
up yours
Not applicable to Passon's 18 spline OD kit.
[Re: Finoke]
#1916855
09/21/15 05:27 PM
09/21/15 05:27 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Was the bellhousing dialed in? Have you measured the exact clutch clearance with the pedal fully depressed?
I'm thinking the 1-2 shift is less forgiving than the others so any irregularities like the above will show up more on that shift.
[Re: Supercuda]
#1917183
09/22/15 01:18 AM
09/22/15 01:18 AM
Magnum
Not applicable to Passon's 18 spline OD kit. Both have a 2.6 1st. Stock 2nd gear is 1.93. Passon 4 spd OD 2nd is 1.59, which is wider.
[Re: John_Kunkel]
#1917201
09/22/15 02:00 AM
09/22/15 02:00 AM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
I'm thinking the 1-2 shift is less forgiving than the others so any irregularities like the above will show up more on that shift. Yes, bell housing was dialed in. I Set the clutch engagement until the throw out bearing doesn't spin with the engine but Its very close. Clutch is definitely fully disengaged when pedal is depressed.
[Re: Magnum]
#1917680
09/22/15 09:35 PM
09/22/15 09:35 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Good link Supercuda, its 3.09 to 1.6. Thats even wider than I originally thought. Yes, but remember this is a conversion, it started out as an 18 spline so not necessarily true that you have lower 1st gear.
