Re: 440 jerking/surge while cruising and light acceleration
[Re: Supercuda]
#1920946
09/28/15 12:05 AM
09/28/15 12:05 AM
RapidRobert
I was trying to enlighten the OP. Oh OK, I misinterpreted. I apologize, my bad/my mistake
[Re: CoDart]
#1920975
09/28/15 12:47 AM
09/28/15 12:47 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Nah, I poorly wrote it is all
[Re: CoDart]
#1921526
09/28/15 11:13 PM
09/28/15 11:13 PM
Posts: 31,106 Oregon
AndyF
After some more cruising I found that if I plug off the manifold vac advanced on the distributor the car does not surge when accelerating or cruising. I think I need to hook the advanced up as PORTED but I do not have a ported port on my Holley. What do I need to make it ported?
Thanks! Street cars should almost always use ported vacuum to avoid cycling the vacuum advance at low throttle position. Adding a ported vacuum port to a HP Holley isn't easy though. Basically you need to buy a different base plate. You might be able to find an old time carb guy who can modify your base plate but it is probably cheaper to buy a new one. I think the HP main body will be drilled for the ported vacuum but you should probably check first. I've converted them over before but that doesn't mean that all of the main bodies are the same.
