Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: BDS871Cuda] #191571
01/13/09 06:21 PM
01/13/09 06:21 PM
gregsdart Offline
gregsdart  Offline
BDS you might get real close to the terns with a differant gear!
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: gregsdart] #191572
01/13/09 06:39 PM
01/13/09 06:39 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I love your Fury BDS, got any more pics.
Sorry to hijack.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: ajcasini] #191573
01/13/09 07:11 PM
01/13/09 07:11 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
I'm doing well, AJ, thanks for asking. Well for an old man who has the snot beat out of him raising Heather, Kyle, and Kevin. Seriously, a day at a time, I am grateful for each day I can be veritical and taking nourishment.
Kyle wanted to do some chopping on my car....I told him no and he got so mad at me he went out and bought a couple of his own.
Your combo intriques me....it runs so well. You use Cal Tracs, yes? What were the et changes in them, by themselves? What were you using before?
It seems to me, that for the price of Cal Tracs, one could go to a good ladder bar setup and be better off. But, I know you win quite a bit, and are incredibly constistent with them. What are your thoughts?
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: Steve1118] #191574
01/13/09 11:41 PM
01/13/09 11:41 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Yeah I had heard Kyle bought another one. A 64 right?
I will tell you the combo surprised me a bunch too. I figured at best the car would 11.50. Heck when I was picking components I chose things I thought would put the car around 11.90 - 12.00.
When I first put the cal-tracs on I was running a 500" wedge.
Before Cal Tracs I just had the pinion snubber with SuperStock Springs.
Reason I went with the cal tracs is the 500 hit so hard it bent the pinion snubber into the yoke and broke the drive shaft ears off.
Anyway performance gain.
Before Cal trac 1.55 best 60' ET
After Cal trac 1.45 best 60' ET
Overall ET was better by about .15 - .2
What I really liked about them is that I do not spin anywhere and if I do simply adjust the bars.
The best part about them is that it keeps the suspension loaded down track. Before the Cal tracs my butt would pucker at around 1200' cause the car would walk around. Now the car is solid as a rock running.
As for why I chose the Cal tracs and not ladder bars. 1. Price 2. Didnt have to cut up the car.
My expenses included ~400 for the cal tracs and 100 bucks for longer rear shocks. I do not use the mono leaf, still have the super stock springs.
IMO Cars running in the 10.50 and up range will all benefit almost as much from cal-tracs as they would ladder bars. (not to mention have about 2500 bucks more in the pocket).
The only thing I wish I would have done when I bought them was buy the adjustable shocks. I have them on for this season and they should be great to fine tune for reaction time.
AJ
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dragula426] #191575
01/14/09 10:59 AM
01/14/09 10:59 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
A similar camshaft but ground on 108 to 110 lobe separation, and a jump in stall speed to something over 4500 should probably do it with no other changes.
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: DaytonaTurbo] #191576
01/14/09 02:00 PM
01/14/09 02:00 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Your combo looks like it should be going faster than it is. Look at 383man's combo, he's got a great old-school combo putting down excellent numbers for a street/strip car. Nothing fancy there except for some well matched components.
Maybe that cam of yours is hurting you. You say it'll diesel if you run on 91, and with all that duration that makes me wonder. You've got enough duration, but on that 112 lobe seperation you are hurting your top end/mid range.
Thank you for the kind words Daytonaturbo. Ron
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: deaks] #191577
01/15/09 01:26 AM
01/15/09 01:26 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Sorry to hijack.
Mick
Hi Mick,
I have a few different pictures in the garage.
When I get a new scanner I will send you some.
Hey Greg,
I hear ya on the 4.56's. I wanted to even try
4.30's with a 200 shot of OJ.
Snap your neck, mega G-force launch, is all I want!
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: BDS871Cuda] #191578
01/15/09 08:52 PM
01/15/09 08:52 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
Here's one for you with almost all stock components. I run it in a 3700 pound (with me in it) Road Runner. It has a 727 (flashes at 4200), 4.30 gear,
Combo is:
.040 over stock 440
Stock crank
Probe 12.5:1 pistons (actual ratio is 13.1:1)
pistons have .990 pins.
Stock rods (non-six pack) that have had the beams ground, bushed,and balanced.
Professionally, race ported heads (452) with 2.14/1.81 valves.
Comp Solid roller cam #23-742-8
.262/.262 @.050, 110 lobe separation, installed on .105 centerline.
Heads are 452's with Crane gold rockers (.015 tapet lift).
I run a stock (non-port matched) 6 pack intake. The carbs are stock with threads tapped into the metering plates for easy jet changes (Pro Max Carbs).
I have run a best ET of 11.178 @121.55 at Atco in NJ. The elevation was just over 600 feet. The car was run with M & H 275-60-15 cheater slicks with open headers (uncapped 2" street Hookers).
The best 60' with this combo is 1.613.
I know the compression ratio is high on this. And yes...race gas is hugely expensive, and I hate the fact that I rarely street drive the car. The truth is, the six pack is not set up ideally. I believe there are 10's in this combo with a good 4-barrel and single plane intake. I wonder what it would do with a 10.5:1 ratio. I bet it would still run low 11's. There was plenty of tire spin with this combo, and I only ran it at the track once.
The reason there is so much compression is the 452's had previously been shaved .100" to gain compression on another combo. I put this together from used parts that were sitting around our shop.
I think if you built a similar combo, but used your Eddy Heads, an M1 or close, and your 850 Holley, you'd be running 10.80's.
I plan to find out what the combo will run with slicks and a good intake and carb combo soon.
Good luck, and the 'lite looks awesome. What color is that?
Tom
