Re: DOT Tires for a 4 speed manual?
[Re: DLewis]
#1914837
09/18/15 03:31 AM
09/18/15 03:31 AM
Posts: 5,167 CT
GTX MATT
CT
Are you trying to run a radial or a bias ply?
[Re: DLewis]
#1914870
09/18/15 09:39 AM
09/18/15 09:39 AM
Posts: 192 WI
mopar873
WI
Myself and others beat our heads against the wall trying drag radials with manual trannies. Even with fully adjustable suspensions they are very tricky. They can technically be faster, but theyre very inconsistent. We've had good luck with MT ET street bias blys and Hoosier quicktime DOT Pros. I drove my car a bunch with both types (35 mile round trip to work), and both kinds (bias plys and radials) wore at about the same rate. Shouldnt drive in any moisture with either tire. Best street psi for a heavier car with the bias ply street slicks was about 25psi.
[Re: DLewis]
#1914909
09/18/15 11:09 AM
09/18/15 11:09 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
30x12.5 M/T ET Street bias ply.
[Re: DLewis]
#1914944
09/18/15 11:46 AM
09/18/15 11:46 AM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
Anyone using the M&H musclecar bias ply tires?
unions....the folks who brought you the weekend!
[Re: DLewis]
#1914966
09/18/15 12:26 PM
09/18/15 12:26 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
If its a drag only car go with the bais ply M&H's. I run my e-body on the street with Nitto Drag Radials 325-50/15's.
They hook up great on the street, last for over 10 k or 2 years, are rated at 186 mph and wont normally pick up stones etc. They will not dead hook in 1st though, and can be driven in the rain with care. The sheer size of the tires make them prone to hydroplane in a decent rain at freeway speeds.
I also run them (275-60-15's) on my automatic a-body, and they will dead hook on the street once warm with perfect conditions, otherwise they will still spin. I run them both at 18psi.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: GTX MATT]
#1915566
09/19/15 11:24 AM
09/19/15 11:24 AM
Posts: 103 Minnesota
DLewis
Minnesota
Are you trying to run a radial or a bias ply? I had planned on running Radials and wasn't aware of the inconsistency issues when running with a 4 speed. The car will primarily be used on the street with an occasional trip to the track. Unlikely to be driven if there's much chance of rain. I found an article HERE that I thought was useful as well.
