69 D100 fuel tank, anyone repo these? #1911546
09/13/15 10:57 AM
09/13/15 10:57 AM
Tampa Bay,Fl.
mopargreg Offline OP
Tampa Bay,Fl.
Hey guys, any of you find repo fuel tanks for behind the seat? I don't really want to move my tank, just looking for a new one. I had this one cleaned and resealed about 20 years ago but the Florida humidity has not been kind to it, gotta change my fuel filter about every 3 months and yes I run dual filters, one from the tank feed and one under the hood.
Re: 69 D100 fuel tank, anyone repo these? [Re: mopargreg] #1912305
09/14/15 04:28 PM
09/14/15 04:28 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
You won't find one unless you can make another truck brand's fuel tank work.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 69 D100 fuel tank, anyone repo these? [Re: mopargreg] #1912601
09/14/15 11:12 PM
09/14/15 11:12 PM
Tampa Bay,Fl.
Tampa Bay,Fl.
I thought about older model Chebbie or Ferd tank from LMC trucks, just have to do some measuring and check fill neck position. If any of you guys have any suggestions I'm all ears, I wanna keep the tank in the cab though.
Re: 69 D100 fuel tank, anyone repo these? [Re: mopargreg] #1912993
09/15/15 01:39 PM
09/15/15 01:39 PM
dogdays Offline
dogdays  Offline
You like the concept of sitting in a metal box with 18 gallons of highly flammable liquid. Your choice.
My next tank is going to be under the bed somewhere.
Plus, it opens up space behind the seat for useful things.
My twocents
R.
Re: 69 D100 fuel tank, anyone repo these? [Re: mopargreg] #1913316
09/15/15 10:19 PM
09/15/15 10:19 PM
Tampa Bay,Fl.
Tampa Bay,Fl.
Could be worse, could be on 2 wheels with highly flammable liquid between my legs...
Re: 69 D100 fuel tank, anyone repo these? [Re: dogdays] #1913335
09/15/15 10:28 PM
09/15/15 10:28 PM
IN
ahy Offline
ahy  Offline
IN
If there is still metal left, may be able to clean and seal again. I have had good luck with the Eastwood 3 step kit (detergent, acid, acetone, sealer) for rare tanks. Kinda messy but works well.
Though personally I would get it out of the cab by adopting a later model tank for all the reasons mentioned. I'm pretty sure brand F and C in cab tanks are hard to find or unavailable because of liability fears.
Re: 69 D100 fuel tank, anyone repo these? [Re: mopargreg] #1913688
09/16/15 02:16 PM
09/16/15 02:16 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Google: Moyer Fuel Tank Renu
They did a tank for me that was not reproduced and it has worked very well for me.
They cut them apart, sand blast everything, fix any rust damage, coat the inside etc. I think the prep for the coating on the inside is key and they have it down. I thought it was reasonable. I think around 350 or so but don't quote me.
