Re: Oil Pressure on the Brakes
[Re: ahy]
#1909620
09/09/15 11:48 PM
09/09/15 11:48 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Fully baffled road race oil pan.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#1909624
09/09/15 11:49 PM
09/09/15 11:49 PM
amxautox
Maybe with a swinging pickup.
Tom
author unknown
[Re: ahy]
#1909638
09/10/15 12:00 AM
09/10/15 12:00 AM
Posts: 22,695 Bitopia
jcc
Bitopia
I would be concerned enough to resolve the issue. Above suggestions plus a 3 qt accusump. I usually wait to brake until I see god, you'll miss him if you are constantly watching your oil pressure.
[Re: ahy]
#1910191
09/10/15 09:49 PM
09/10/15 09:49 PM
amxautox
To have both NEVER hurts.
Tom
author unknown
[Re: ahy]
#1910534
09/11/15 01:59 PM
09/11/15 01:59 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
That road race pan looks really nice... I have heard its a very tight fit though... anybody running one? Also wonder if the road race pan alone is enough or also need the Accusump? You may be thinking of my pic of an small block in a 73-76 a-body K-frame. The big block road race in a b or e body has alot more room than a small block in a A-body. I believe you can install that pan without taking motor out. I had an pro instructor drive my car hard with the stock pan and sucked the pan dry. We had to come in on the second lap. With the new Mildon pan, same pro driver same track we had no issues. SB road race pan has same sump as BB pan just a little smaller for clearance in spots.
[Re: ahy]
#1910733
09/11/15 08:48 PM
09/11/15 08:48 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I used that pan in A-body.
Mopar to the bone!!!
[Re: autoxcuda]
#1910885
09/12/15 12:54 AM
09/12/15 12:54 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
That road race pan looks really nice... I have heard its a very tight fit though... anybody running one? Also wonder if the road race pan alone is enough or also need the Accusump? You may be thinking of my pic of an small block in a 73-76 a-body K-frame. The big block road race in a b or e body has alot more room than a small block in a A-body. I believe you can install that pan without taking motor out. I had an pro instructor drive my car hard with the stock pan and sucked the pan dry. We had to come in on the second lap. With the new Mildon pan, same pro driver same track we had no issues. SB road race pan has same sump as BB pan just a little smaller for clearance in spots. Hasn't the small block pan been discontinued since last year? Edit: Nevermind, it's still on their website. Sure is a pricey unit. http://www.milodon.com/oil-pans/road-race-oil-pans.asphttp://www.summitracing.com/parts/mil-31595/overview/make/dodge
[Re: MuuMuu101]
#1910940
09/12/15 03:21 AM
09/12/15 03:21 AM
autoxcuda
So Cal
That road race pan looks really nice... I have heard its a very tight fit though... anybody running one? Also wonder if the road race pan alone is enough or also need the Accusump? You may be thinking of my pic of an small block in a 73-76 a-body K-frame. The big block road race in a b or e body has alot more room than a small block in a A-body. I believe you can install that pan without taking motor out. I had an pro instructor drive my car hard with the stock pan and sucked the pan dry. We had to come in on the second lap. With the new Mildon pan, same pro driver same track we had no issues. SB road race pan has same sump as BB pan just a little smaller for clearance in spots. Hasn't the small block pan been discontinued since last year? Edit: Nevermind, it's still on their website. Sure is a pricey unit. http://www.milodon.com/oil-pans/road-race-oil-pans.asphttp://www.summitracing.com/parts/mil-31595/overview/make/dodge Ask Hotchkis about the custom aluminum Moroso pan up in the rafters of the shop they had made for the Yellow Challenger. Leaked and not as many gates and smaller than the Milodon ones.
[Re: jcc]
#1911081
09/12/15 02:12 PM
09/12/15 02:12 PM
autoxcuda
So Cal
I think the confusion on the road race oil pan centers around the withdrawal of the DIY road race oil pan kit, which has been discussed here and this only makes sense I suspect if the manufacturers decided they could earn a greater profit selling complete pans, instead of the kit a customer could customize for their own particular set-up. Maybe If those kit buyers would had understood they were buying something they would have to fabricate themselves and take responsibility for themselves. Shame a few could ruin it for the whole. I have a old Moroso Kit. It's a little bit of a head start. But about every piece would have had to be cut down for fitting into my stock framed situation. Many parts rebent or notches cut. The pieces in the kit are not real brain surgery. It's better suited for a fab clip circle track car with lots of room. And that is what it's was designed for. A person with the competent skill set and tools to build the kit into a custom pan ALSO has about the same skill set and tool to built the pan from scratch. It's like making a subframe connector "KIT" with two straight tubes and a hacksaw blade. But nowadays everyone wants to be empowered whether they deserve it or not. Then they demand their hand held, be coddled, and blame someone else for their own mistakes. If you spend a hour instructing someone how to DIY over the phone, a manufacturer could have just made it themselves in the same amount of time. And at least in that case they would have know the person building is remotely qualified to do so.
[Re: ahy]
#1913724
09/16/15 02:55 PM
09/16/15 02:55 PM
Posts: 30,994 Oregon
AndyF
Sounds like I have a winter project... I'll do the pan first and go from there. Good idea, do the pan first and see if that solves it. If not, you can always add the accusump which will solve it but is expensive and heavy and somewhat complicated. By the way, when you install the road race pan go ahead and add an oil temp sending unit at the same time. Once you start watching oil temp you'll learn a bunch.
[Re: AndyF]
#1914406
09/17/15 01:08 PM
09/17/15 01:08 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I'm planning to get a SB Miloden road race pan (engine out of car now, rebuilding time... past stock welded/baffled pan has served well), but one thing that puzzles me is the very rear-most area ... pictures show it squared off, as though it would be holding a small collection of oil without drainage to the bottom sump. It looks as though the pan is cut by Miloden and raised/dammed just in front of that rear area, completely different than a stock pan. Maybe the BB pan is the same. Does anyone know the reason for the rear area being changed? I've never actually seen one of these pans (SB or BB).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#1914428
09/17/15 01:47 PM
09/17/15 01:47 PM
autoxcuda
So Cal
I'm planning to get a SB Miloden road race pan (engine out of car now, rebuilding time... past stock welded/baffled pan has served well), but one thing that puzzles me is the very rear-most area ... pictures show it squared off, as though it would be holding a small collection of oil without drainage to the bottom sump. It looks as though the pan is cut by Miloden and raised/dammed just in front of that rear area, completely different than a stock pan. Maybe the BB pan is the same. Does anyone know the reason for the rear area being changed? I've never actually seen one of these pans (SB or BB). The back wall of the sump keeps oil from spilling over out of the sump. The taller that back wall, the better at keeping oil in the sump area. Well on a small block the rear floor height is dictated by the height of the oil pump not the rotating assembly like on most motors. Without the oil pump, the rear floor on a small block could be 1/2" or so closer to the crank. Remember some people rubbing holes in pans with thicker HV oil pumps? It happened to me once. The lower the rear floor of the oil pan, the shorter the back wall of the sump is and more oil spilling out of the sump pickup. So what Milodon does with their small block Lo-Pro and Road Race pans is to make them think they are a deeper sump while achieving better ground clearance. I know it seems like oil will be trapped in the back. But it's very shallow and hot oil comes down the block to fill that area and with movement of the car oil spills out and is refilled. Also, this is a high performance part. Not grandma's Buick or a new car with 5,000 miles oil change intervals that people still forget to do. Cars with this type of pan don't/shouldn't wait for their oil to be black to change it. It gets changed every race, every few races, every year of occasional fun car driving, or some much shorter than average interval. And that would happen whether you had this pan or not.
[Re: ahy]
#1914444
09/17/15 02:23 PM
09/17/15 02:23 PM
autoxcuda
So Cal
[Re: Mopar Mitch]
#1914832
09/18/15 02:31 AM
09/18/15 02:31 AM
Posts: 65 Victoria B. C Canada
gold66cuda
I'm planning to get a SB Miloden road race pan (engine out of car now, rebuilding time... past stock welded/baffled pan has served well), but one thing that puzzles me is the very rear-most area ... pictures show it squared off, as though it would be holding a small collection of oil without drainage to the bottom sump. It looks as though the pan is cut by Miloden and raised/dammed just in front of that rear area, completely different than a stock pan. Maybe the BB pan is the same. Does anyone know the reason for the rear area being changed? I've never actually seen one of these pans (SB or BB). I have the small block road race pan in my car and was also concerned a bit with the oil being trapped in the back of the pan. My concern was more that when changing the oil that the better part of a quart (or liter where I live) of dirty oil would be stay in the pan when draining out the oil. If I wasn't in a bit of a rush when I installed the pan I would have welded in a bung plug in the back area to drain out this oil, will do it over the winter. Another option would be to weld in a 1/2" tube or two on the side of the pan to connect the two sumps. The pan does work well, I have run a few events with it this year and have never seen the gauge bounce.
