Re: Nos 70 cuda tail panel
[Re: ek2aar]
#1909697
09/10/15 01:50 AM
09/10/15 01:50 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
The parts are legit. One major seller has a ton of NOS sheet metal. More and more NOS parts will be hitting the market as the older guys get out of the hobby. So, that is good news for people that want OEM Mopar.
China is the enemy.
[Re: mccannix]
#1912422
09/14/15 08:21 PM
09/14/15 08:21 PM
Posts: 349 West Central Wisconsin
DeMopuar
Have to be careful in this day of the $$ is everything. Several years back some "NOS" Cuda trunk pans seemed plentiful at a major show. After one sold, out would come another one. Red oxide Primer and silkscreened number looked a little too fresh.
I've even found the odd vendor to have repro parts in NOS part numbered Mopar boxes. I agree Terry, you've got to be VERY careful when you're parting with your cash. I saw at the Nats this last year that there seemed to be three different big time vendors that were working it together. I think there is more than a little collusion going on with these three guys. I think that one guy will have NOS this or that (that really isn't NOS, it's just made to look that way), and the other two clowns will sell his NOS crap that really isn't. If you guys that are doing this are reading this, well, the jig is up. I at least know who you three clowns are, and the thing is, you have NO idea who I am. I look for the die stamp numbers on NOS sheet metal pieces from the early 70's. I believe there should always be these stamps on sheet metal pieces, even if it's lightly stamped? Has anyone else seen this on the true NOS pieces?
[Re: ek2aar]
#1912616
09/14/15 11:23 PM
09/14/15 11:23 PM
Posts: 2,309 South, FL
cudaized
South, FL
[Re: DeMopuar]
#1914252
09/17/15 04:13 AM
09/17/15 04:13 AM
Posts: 1,177 People's Republic of Kali
70runner
I look for the die stamp numbers on NOS sheet metal pieces from the early 70's. I believe there should always be these stamps on sheet metal pieces, even if it's lightly stamped? Has anyone else seen this on the true NOS pieces? I think the word "always" should be used carefully when addressing Chrysler OE parts from the 70s. Case in point, I had probably the last NOS quarter panel for a 70RR convertible in captivity until it went on my car in 2011. Nobody has ever reproduced them. This panel had a stenciled part number, no die stamp anywhere.
[Re: DeMopuar]
#1914313
09/17/15 10:29 AM
09/17/15 10:29 AM
Posts: 4,782 Ontario, Canada
mccannix
Ontario, Canada
[/quote]I agree Terry, you've got to be VERY careful when you're parting with your cash. I saw at the Nats this last year that there seemed to be three different big time vendors that were working it together. I think there is more than a little collusion going on with these three guys. I think that one guy will have NOS this or that (that really isn't NOS, it's just made to look that way), and the other two clowns will sell his NOS crap that really isn't. If you guys that are doing this are reading this, well, the jig is up. I at least know who you three clowns are, and the thing is, you have NO idea who I am. I look for the die stamp numbers on NOS sheet metal pieces from the early 70's. I believe there should always be these stamps on sheet metal pieces, even if it's lightly stamped? Has anyone else seen this on the true NOS pieces? [/quote] This pretty much sums it up. I can say with certainty that any of these items being discussed here are not AMD pieces stripped, primed and numbered. The "NOS" trunk floors appeared a while before AMD arrived on the scene. The "NOS" tailpanels ..likely around the same time frame Watch for more "NOS" coming to a show near you
[Re: ek2aar]
#1914793
09/18/15 12:53 AM
09/18/15 12:53 AM
mccannix
Ontario, Canada
^^Lol, so the tail panels that you are talking about do not have the dye stampings? ....for now, once this thread gets read, they'll likely get added.
[Re: DeMopuar]
#1918032
09/23/15 01:23 PM
09/23/15 01:23 PM
Posts: 5,268 NY
70440+6bbl
NY
I've even found the odd vendor to have repro parts in NOS part numbered Mopar boxes. I agree Terry, you've got to be VERY careful when you're parting with your cash. I saw at the Nats this last year that there seemed to be three different big time vendors that were working it together. I think there is more than a little collusion going on with these three guys. I think that one guy will have NOS this or that (that really isn't NOS, it's just made to look that way), and the other two clowns will sell his NOS crap that really isn't. If you guys that are doing this are reading this, well, the jig is up. I at least know who you three clowns are, and the thing is, you have NO idea who I am. I look for the die stamp numbers on NOS sheet metal pieces from the early 70's. I believe there should always be these stamps on sheet metal pieces, even if it's lightly stamped? Has anyone else seen this on the true NOS pieces? I know of a fellow in NY that has (had?) a pair in his basement and another set mounted on a V-code ragtop.
